obd-0/obd-1 block swap question: need help!
Old Jan 3, 2005 | 06:35 PM
hybridej7's Avatar
Default obd-0/obd-1 block swap question: need help!
ok, ive got a 91 integra ls. the block is bad, im pulling it and replacing it with a 93 ls block. which i just realized is that it is obd-1, my car is obd-0. on the back of the block, it has a plug with 2 connectors on it that the obd-0 block doesnt have. it is right next to the oil filter location. i was told that i can use a 92-93 ecu, and it will eliminate that plug. which ecu do i need to use or is there a way to bypass that plug and use the obd-0 engine harness/ecu?
bump for any help.....
Old Jan 4, 2005 | 08:06 AM
gt30typer's Avatar
Default Re: obd-0/obd-1 block swap question: need help! (hybridej7)
one for sure is the coolant temperature, it is the one with a black boot covering it, and has two small circular connectors in it, Now all you have to do is take those wires and plug it into the coolant temperature swith on the back of the thermostat housing off of the newer motor. If you do not have that you can always make a coolant temp block that T's into one of the colant line and holds the old sensor off the block. The first is much cleaner and really is the right way to go. What does the other plug look like ? how many wires?
Old Jan 4, 2005 | 10:34 AM
hybridej7's Avatar
Default Re: obd-0/obd-1 block swap question: need help! (gt30typer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gt30typer &raquo;</TD></TR><TR><TD CLASS="quote">one for sure is the coolant temperature, it is the one with a black boot covering it, and has two small circular connectors in it, Now all you have to do is take those wires and plug it into the coolant temperature swith on the back of the thermostat housing off of the newer motor. If you do not have that you can always make a coolant temp block that T's into one of the colant line and holds the old sensor off the block. The first is much cleaner and really is the right way to go. What does the other plug look like ? how many wires?</TD></TR></TABLE>
i cant remember off the top of my head, but its a 93 ls obd-1 longblock. are there 2 wires on the 93 block that i can plug into or is there only 1? if only 1, how can i wire it up?
Old Jan 4, 2005 | 10:39 AM
gt30typer's Avatar
there should be two the sensor ground and signal, just get the plug end with a pigtail and wire it up ground to ground and so forth. if there is one wire , wire it to the signal wire.
Old Jan 4, 2005 | 11:06 AM
hybridej7's Avatar
ok cool. i will have to look tonight when i get home. ill post any other questions i may have tonight when i get home and look at it.......
bump for the help...
Old Jan 4, 2005 | 05:46 PM
hybridej7's Avatar
ok i got some pics:
how do i take these wires from the 91 b18a block:
http://www.we-todd-did-racing....D.jpg
and put them into the 93 b18a block here:
hope this helps, thanks for all the help....
Old Jan 4, 2005 | 05:47 PM
gt30typer's Avatar
you got it
Old Jan 5, 2005 | 08:21 AM
hybridej7's Avatar
bump for some help.....
Old Jan 5, 2005 | 03:43 PM
Cjsls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridej7 &raquo;</TD></TR><TR><TD CLASS="quote">ok i got some pics:
hope this helps, thanks for all the help.... </TD></TR></TABLE>
you need the clip that goes into the sensor deely in the second pic....as long as you have that then just cut the wires from the 1st pic and splice into the connector so you can plug it in. i did this when i did my swap....i had an extra wire harness laying around.
Old Jan 6, 2005 | 04:18 AM
hybridej7's Avatar
Default Re: obd-0/obd-1 block swap question: need help! (Cjsls)
yea i picked up a clip last night and i got that figured out. my next problem is, the obd-0 dizzy wont fit on the obd-1 head......what now? what can i do? it looks like the piece that goes into the head and turns the cam wont work right.......arghh.... i just wanna get my car running again......
Old Jan 6, 2005 | 04:43 AM
DA-MAX's Avatar
are you sure you're just not getting the keyway all the way in there snug...sometimes it takes a little jiggling to have it fall into place...even when just replacng it on an OBD0 motors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridej7 &raquo;</TD></TR><TR><TD CLASS="quote">yea i picked up a clip last night and i got that figured out. my next problem is, the obd-0 dizzy wont fit on the obd-1 head......what now? what can i do? it looks like the piece that goes into the head and turns the cam wont work right.......arghh.... i just wanna get my car running again...... </TD></TR></TABLE>
Old Jan 6, 2005 | 05:54 AM
hybridej7's Avatar
Default Re: obd-0/obd-1 block swap question: need help! (DA-MAX)
yea, i tried. the key where it goes into the end of the cam even looks smaller. i put the 2 dizzys up next to each other and the obd-0 one is smaller than the obd-1 keyway. if thats the deal, can i switch the 2 to make one of them work? anything else i can try??
Old Jan 8, 2005 | 02:07 PM
hybridej7's Avatar
got it all to work....thanks for all the help....
mods you can delete this topic if you would like too.......
Modified by hybridej7 at 10:28 AM 1/10/2005
m.glisson003
Dec 15, 2011 04:27 AM
JDMB20TDA
Mar 9, 2009 07:14 PM
SPOOLINmatt
Jun 20, 2005 09:29 AM
Sketch_hs
10
Oct 22, 2004 09:57 AM
