Need help with knock sensor!!!!!
Old Jan 3, 2005 | 05:27 PM
lsvtec92teg's Avatar
Default Need help with knock sensor!!!!!
OK......I have a ls/vtec in my 92 integra that i built myself(except machine work). It is now in my car and runs well but i have a few tuning issues, starting with the knock sensor. As there is no spot in the b18 block for a knock sensor, i have not installed it yet. so my question is.... will the b16a1 computer fully retard the timing as a safe mode since it sees no input from knock sensor. Also, if so would that be contributing to my rich at idle/lean under heavy throttle?????????
Any input would be much appreciated!!!!!!!!
Old Jan 3, 2005 | 07:12 PM
MugenRacerX's Avatar
Srry I wanna answer your question but dont remember if that ecu looks for knock I wanna say yes but im not certain rite now.
Cspeedracing has a nice discription of where how to mount the knocksensor by removing the top altenator bolt and tapping it there.
Old Jan 3, 2005 | 07:19 PM
Default Re: (MugenRacerX)
It does look for knock because im getting a knock sensor code. Im just not sure what it is doing to my timing
Old Jan 7, 2005 | 01:18 PM
Jun8386's Avatar
Just run a chipped P28 or run Hondata.
Old Jan 8, 2005 | 07:59 AM
jdm420da6's Avatar
Default Re: (Jun1993)
if anything, have knock sensor removed from ur program, assuming u are going to do some ecu tuning.
gabrielsousa
Nov 4, 2015 04:12 PM
hondakrazy
Nov 14, 2008 10:42 AM
1.5boosted
Dec 14, 2007 01:45 PM
jdm_h22power
Apr 5, 2006 12:10 AM
untitled
Aug 8, 2003 08:03 PM
