AEM EMS gurus, need help with Idle tunning
Old Jan 3, 2005 | 03:42 PM
shermanyang's Avatar
Default AEM EMS gurus, need help with Idle tunning
i've got a problem, everytime my temp. goes below 140 or so degrees my motor spins at 3k and becomes unbearably loud. this happens at startup and stoplight to stoplight driving and is VERY annoying for myself and everyone around me. i know that this is normal but is there a way to stop this from happening? like say have the RPM hold at 1.5k from 120 degrees F. to 1 degrees F ?? if this is possible...please explain how i would go about doing so.
Old Jan 3, 2005 | 03:48 PM
SOHC_MShue's Avatar
Default Re: AEM EMS gurus, need help with Idle tunning (shermanyang)
[QUOTE=shermanyang] i know that this is normal but is there a way to stop this from happening? QUOTE]
i'm pretty sure that having a 3k rpm idle isn't normal
Old Jan 3, 2005 | 03:53 PM
Default Re: AEM EMS gurus, need help with Idle tunning (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=shermanyang] i know that this is normal but is there a way to stop this from happening? QUOTE]
i'm pretty sure that having a 3k rpm idle isn't normal </TD></TR></TABLE>
LOL...i know, but once it heats up to 'normal op. temps' it stays at 900 RPMS. i would just like it to stay that way even when the coolent temps are below regular operating temps.
Old Jan 4, 2005 | 07:08 AM
D-tuned's Avatar
your idle vs target table is all jacked up. the value that you have entered at 1500 rpms, enter that value into all rpms after 1500rpms so that you will have a straight line. your hi idle offset is way to high. 5 sec's is allot. 1 to 1.5 secs is what I normally use on cars when I set them up. make those changes and let me know if it helps. are you can pm me you cal and I'm make sure adjustments for you
Old Jan 4, 2005 | 09:14 AM
B18CXr's Avatar
ditto
Old Jan 4, 2005 | 08:06 PM
Default Re: AEM EMS gurus, need help with Idle tunning (B18CXr)
alright, i'll go and fix that tomorrow at work then i'll let you guys know how it all goes. i was sick today and slept all day so i couldn't make any adjustments. thanks for your inputs.
sshh
Engine Management and Tuning
Jan 28, 2011 11:52 AM
hidden sol
Oct 16, 2006 09:53 PM
lshatch92
21
Oct 28, 2005 06:38 PM
BodyKits NW
Aug 20, 2005 08:16 PM
EFStali
10
Aug 19, 2003 09:14 PM
