A couple more backpurge pics(8 guage).
Old Jan 3, 2005 | 03:08 PM
Tinker219's Avatar
Default A couple more backpurge pics(8 guage).
Single pass, Mid 200 amps or so with pulser activated.
Thought Id show everyone, its part of the 2nd to last B SST Ill ever make.
Old Jan 3, 2005 | 04:29 PM
B18C1CYA's Avatar
Default Re: A couple more backpurge pics(8 guage). (Tinker219)
do you use a filler on that ??? looks great
Old Jan 4, 2005 | 04:48 AM
Tinker219's Avatar
Default Re: A couple more backpurge pics(8 guage). (B18C1CYA)
Ya, on beveled elbows, filler is need otherwise is ends up VERY concave. I can do this with no filler on two 8 guage pieces flat-butted together. I measured before and after lengths, it was around .030 difference, and the weld was very flat on the outside, slightly convex on the inside. I recently emptied my scrap bin, so no pictures of that(Ill try again soon, its great practice if you take a day or two off).
Again, I want to reitterate, CONSTANT pedal position(slight adjustment as you go, to compensate for heat-soak), I just dont feel confident enough(nor have the time to completely learn how to re-weld) to do this without the pulser helping me out. Seems to work great using this method and its MUCH faster than pedal pumping!
Old Jan 4, 2005 | 08:26 AM
mopar junkie's Avatar
tinker, can you post some pics of your backpurge setup? I've been looking for some pics of how to set it up but they are hard to find....
Old Jan 4, 2005 | 11:48 AM
Tinker219's Avatar
Default Re: (mopar junkie)
I will only say that I have a designated tank and regulator for backpurging only. The rest can be had if you search in these forums a little harder. I woudl be more forthcoming, but I came up with this stuff on my own, with my own sweat, and it makes it a little harder to give away. Merge collectors for example, I told a few people, every one of them started their own business because of it. No names, but those people know who they are, and I can no longer disclose anything else. SOrry
Old Jan 4, 2005 | 11:52 AM
B18C1CYA's Avatar
Default Re: (Tinker219)
i totaly understand what you are saying ,
Old Jan 4, 2005 | 12:01 PM
thermal's Avatar
Beautiful work Cody. I cant wait to see the actual product!
Old Jan 5, 2005 | 07:40 AM
Full-Race Geoff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">Mid 200 amps or so with pulser activated.</TD></TR></TABLE>
holy crap thats high current!!
Old Jan 5, 2005 | 07:48 AM
david@didrace.com's Avatar
Default Re: A couple more backpurge pics(8 guage). (Full-Race Geoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">
holy crap thats high current!! </TD></TR></TABLE>
Yeah looks more than 100% penetration. I can't imagine it being a benefit for flow.
I wish my camera didn't suck as much, I was playing with Solar Flux instead of backpurging. Solar Flux might not look as nice from the inside but it acts as a barrier to keep you from going over full penetration. It must have silica or something in it because once the weld pool hits the back of the weldment it turns into what looks like glass. Good stuff.
Old Jan 5, 2005 | 10:05 AM
Tinker219's Avatar
Default Re: A couple more backpurge pics(8 guage). (backpurge)
Yep its high, but its what I need to do to get the job done. Doesnt seem to be burning anything excessively, and the burnthrough is not actually as intrusive into flow as it looks in the pictures.
Old Jan 5, 2005 | 02:14 PM
Engloid's Avatar
OG Fabricator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backpurge &raquo;</TD></TR><TR><TD CLASS="quote">I was playing with Solar Flux instead of backpurging. ... It must have silica or something in it because once the weld pool hits the back of the weldment it turns into what looks like glass.</TD></TR></TABLE>
Hope it doesn't come off and go into a turbo one day.
Old Jan 5, 2005 | 02:46 PM
Default Re: A couple more backpurge pics(8 guage). (Engloid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Engloid &raquo;</TD></TR><TR><TD CLASS="quote">
Hope it doesn't come off and go into a turbo one day.</TD></TR></TABLE>
Naw, already thought of that. I was using it on a set of headers I'm working on.
Just took some pictures of my backpurge setup for a pair of headers for a Ram SRT-10. It's nice, I weld up the flanges while their bolted to the jig to keep them from warping. I have each port tapped on the jig to allow for a line to be fed in from the backside.
Modified by backpurge at 12:04 AM 1/6/2005
Old Jan 5, 2005 | 03:55 PM
Engloid's Avatar
OG Fabricator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backpurge &raquo;</TD></TR><TR><TD CLASS="quote">Naw, already thought of that. I was using it on a set of headers I'm working on.
[/i]</TD></TR></TABLE>
Then how are you going to prevent it from comming off? I have heard of problems with it comming off and going into the turbo.
Old Jan 5, 2005 | 04:34 PM
xci_ed6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Engloid &raquo;</TD></TR><TR><TD CLASS="quote">Then how are you going to prevent it from comming off? I have heard of problems with it comming off and going into the turbo.</TD></TR></TABLE>
header = no turbo?
Old Jan 5, 2005 | 04:35 PM
B18C1CYA's Avatar
Default Re: A couple more backpurge pics(8 guage). (krustindumm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">
header = no turbo?</TD></TR></TABLE>
if it was used on a turbo manifold
Old Jan 5, 2005 | 04:45 PM
Turbo-charged's Avatar
i see turbo components...and a ferrarri in the background? details please?!
Old Jan 5, 2005 | 04:51 PM
Canuk_SiR's Avatar
Default Re: A couple more backpurge pics(8 guage). (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">i see turbo components...and a ferrarri in the background? details please?!</TD></TR></TABLE>
its not a ferrari, its a fiero in disguise!
Old Jan 5, 2005 | 05:08 PM
matt_sb2000's Avatar
Srt4 intercooler.
Old Jan 6, 2005 | 07:06 AM
There's a customer's Ferrari, no turbo components. The M3 and Ram SRT-10 both have Vortech superchargers though.
AdeJong 03
Honda Motorcycles
46
Oct 29, 2008 03:27 PM
drift2004
Welding / Fabrication
Dec 14, 2006 07:07 PM
legendboy
11
Nov 6, 2005 07:00 AM
KC
Jan 11, 2005 04:21 PM
phat-S
44
May 27, 2003 12:06 PM
