Grinding Sound from Transmission.
Tranny: 95 GSR
When the car is in neutral, it makes this weird sound like the tranny is grinding on some thing. But stops when I engage the clutch. But makes the sound agian when in gear. At first I thought it was the throw out bearing so I replaced that, but it's still doing it. I have no idea what it is now.
Note: It sounds like 2 peices of moving metal touching each other.
I'm almost certian it's the input bearing after doing some research. But after reading how it's a pain to replace, I'm hoping it's something else.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xaznxboixsirx »</TD></TR><TR><TD CLASS="quote">I'm almost certian it's the input bearing after doing some research. But after reading how it's a pain to replace, I'm hoping it's something else.
Only way to find out is take her apart
</TD></TR></TABLE>Only way to find out is take her apart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GEN2TEG »</TD></TR><TR><TD CLASS="quote">
That's what I will be doing. I haven never really taken a tranny apart before. So hopefully everyting goes right.
</TD></TR></TABLE>That's what I will be doing. I haven never really taken a tranny apart before. So hopefully everyting goes right.
input shaft bearing, same thing happened to my y1. i had to take off the casing and press out the old race which was separated from the inner pieces. pain in the *** to say the least. i had to use a bearing puller from autozone. hope all goes well.
That's what I will be doing. I haven never really taken a tranny apart before. So hopefully everyting goes right.</TD></TR></TABLE>
If you have never done one before I suggest you get someone who has to do it. trust me I have seen friends try to do these and they have had nothing but a PITA of an experience. These are guys who are somewhat mechanically inclined. Trust me get it done by an experienced mech.
I commend you though if you attempt to do it. I also wish you luck (no sarcasm intended)
Thanks for your kind words. I want to play around with this with some friends to learn about transmission. I wouldn't know til I do it so this is gonna be an experience for me and my friends. I'll try to do to a write up.
Transmission can be very intimidating first time you do it
Its easy once you do one
Definitely an input shaft bearing. My old b16 s1 tranny had this same problem.. I got rid of it (cheap) and bought a j1 to replace it. No more problems.
Good luck.
Good luck.
lowbudget88si
Mar 11, 2005 07:16 PM
lowbudget88si
Mar 10, 2005 12:31 PM
