95 Integra abs failsafe relays ???
Old Jan 3, 2005 | 01:33 PM
pumpknocker's Avatar
Default 95 Integra abs failsafe relays ???
My 1995 integra has an abs light on. I tapped into the scs connector and got the code
6-1 which is front failsafe relay. My problem is I can't locate the abs relays. I have manuals that don't mention the relays. I have searched the engine compartment, under the dash, and behind the ecu .... I know their are 2 relays, one for the front and one for the rear. I have even found the abs relays on auto parts sites, they state two is needed for the integra. The abs fuse box under the hood contains a motor relay and fuses. These are not the ones I'm searching for. I even called the Honda-Acura service department, they gave me no help! Please help before I strip the car trying to find them.
Old Jan 3, 2005 | 03:12 PM
appleyard777's Avatar
Default Re: 95 Integra abs failsafe relays ??? (pumpknocker)
hmmmm dont know to much about relays.. n e one familiar?
Old Jan 9, 2005 | 02:30 PM
Default Re: 95 Integra abs failsafe relays ??? (appleyard777)
Well I finally found the relays. They are under the antifreeze overflow container. Both relays are bolted to the front panel. The ABS computer is behind the rear side interior panel next to the speaker. I replaced the front failsafe relay and that solved my problem. My abs light is off now so all is well. I cleaned the engine last week and the abs light came on about 3 hours later.
Apparently I got water in the relay causing it to short and malfunction.
///Apex
Jul 15, 2011 02:25 PM
v-tec maz
Apr 5, 2006 02:13 PM
B2FiNiTY
Mar 12, 2003 11:31 AM
