ignition missing?
ok heres what i got. i installed a hyfire6 and accel super coil. just like the msd stuff so i know its fine. well the reason i changed from stock is obviously to have better spark up top. before i changed my car would missfire at 8.5 or so psi only after i changed turbo and exhaust to 3"straight no muff, but also forgot to reinstall the 2nd o2 sensor.
now that i put in the new ignition it misses about 7 psi and at around 6500 in 2nd and others not first it goes to fast not enough boost i think. if i rev it in neutral it doesnt miss on hits revlimit.
is it because i dont have 2nd o2 in or is it my motor having issues { not thinking this one} but possible}. i have stock plugs i changed them to cooler and still did it.
yeah i uped it to 40% more and it still did it. all it did then was puff out a hella lot of black smoke. i have my water injection also it does it with or without it.
and before with my other turbo i was running 10 psi and no probs then i changed turbo and ran 5 psi no prob then turned up to 8 and then started noticing it.
well no new info. i drove it today and it still does it . ? maybe 2nd o2 maybe im going to put my 21/2 back on and see what the hell. as far as i can see im going to re gap my plugs and see. any thing else anyone can think of.
Hrmmm...Just wondering,
But how do you have the coil mounted? Any pics?
My B18C1 CRX SC61 setup is doing the same thing. I even swapped distributors with no luck. I'm running just a stock distro with an MSD blaster coil
Bryson
Bryson
smoothludey2
Jan 7, 2002 08:00 PM
