98 Prelude SH running to rich and won't start
Old Jan 2, 2005 | 12:45 PM
DB Prelude SHR's Avatar
Default 98 Prelude SH running to rich and won't start
I 1998 Prelude SH started up this moring to back and and wash, it died and will not start back up, we changed the plugs, checked for spark, compression, air and it will not start. fuel pressure gauge is rreading 43psi, is that to high?
these are the mods that I have
AEM fuel rail
B&M fuel pressure regulater
intake
JG pro stock head
DC header
AEM cam gears
AEM over drive and under drive pulleys
no cat
HKS super drager exaust
Old Jan 2, 2005 | 12:50 PM
Hawkze_2.3's Avatar
Default Re: 98 Prelude SH running to rich and won't start (DB Prelude SHR)
That fuel pressure is fine, why don't you do a compression test and check your timing?
Old Jan 2, 2005 | 01:20 PM
98TypeSH's Avatar
Default Re: 98 Prelude SH running to rich and won't start (Hawkze_2.3)
you get any sort of click or sound when you turn the key?
Old Jan 2, 2005 | 04:29 PM
OxYi's Avatar
Default Re: 98 Prelude SH running to rich and won't start (98TypeSH)
Hehe could it be the battery ?
cuz thats my problem last time, thought it was my spark and all that...
same car too
Old Jan 2, 2005 | 06:32 PM
BerryWS6's Avatar
Default Re: 98 Prelude SH running to rich and won't start (OxYi)
I am his friend that was trying to help him, its not the Battery, 1 its an Optima 2 we thought that too and tried to jump it, we also tried to push it and pop the clutch.
no need to do a compression test because it does turn over but never fires off, and you can here it has compression, (even with a loss in compressoin it should still run?) we took the plugs out(5 months old) and they were black as hell, we put new ones in it and still nothing, but after 4 trys we took one of the plugs out and it was covered in fuel!
so we know that it is flooding the engine but why would it just do this out of no were?
Old Jan 2, 2005 | 09:41 PM
boostedlude97's Avatar
Default Re: 98 Prelude SH running to rich and won't start (BerryWS6)
so your not getting spark.........
check the ignition coil and the distributor
Old Jan 3, 2005 | 03:16 PM
BerryWS6's Avatar
Default Re: 98 Prelude SH running to rich and won't start (boostedlude97)
yes we are getting spark
Old Jan 3, 2005 | 09:43 PM
if u were getting spark wouldn't it be burning the fuel??????
Old Jan 3, 2005 | 10:42 PM
BerryWS6's Avatar
Thats what I would think, we took the plug wire out and the plug out its self and put it back in the wire and turned it over and we saw the spark on each one, so we know that the plugs are good (because they're new) and the wires are good because the deleiver the spark to the plug, so If its getting enough? I don't know but there is spark, could the igntion coil have gone bad and not deleiver enough spark to the plugs?
Old Jan 3, 2005 | 10:44 PM
blackdelslo's Avatar
Sounds like distributor problem to me.
Z99doc
Apr 28, 2014 06:26 PM
Rok_Stok
Feb 10, 2011 09:40 AM
oneprelude
Jan 12, 2010 09:52 PM
BoB44
27
Sep 12, 2007 01:54 PM
dj626
Sep 15, 2004 01:09 PM
