lude idle problem...not like the others
Old Jan 2, 2005 | 09:16 AM
92silude's Avatar
Default lude idle problem...not like the others
alright I have a pretty big problem...I just got my head gsaket replaced...and since then, like after I turn my car on after it's been sittin overnight, it'll take a little bit before it'll start, it won't turn over, and then when it finally does the idle is at 800rpm, but if you try to rev it, it doesn't want to...it'll hesitate to rev but after a little bit it will....now once the car is warmed up...the rpms go up to about 1500rpms, and sometimes purges, but then it also sometimes goes back down to the 800rpms when it's warmed up..not very often though....the guy that replaced the gasket said that I didn't have a fuel pressure regulator, or regulator hose...something likke that, and the check engine light also comes on, but not always ...could someone pleaseeee help me out!! thanks
Ryan
Old Jan 2, 2005 | 09:52 AM
ludegetsmwet's Avatar
Default Re: lude idle problem...not like the others (92silude)
well then what is the fault code for the check engine light
Old Jan 2, 2005 | 10:52 AM
92silude's Avatar
yeah I'm definitely a noob to this...how do I know the fault code for the check engine light?
Old Jan 2, 2005 | 09:01 PM
Default Re: (92silude)
go to auto zone and tell them to hook up an on board diagnostics tester or an obd and they can tell you exactly what code you have or what is wrong with your car
Old Jan 2, 2005 | 10:29 PM
s2000 mf's Avatar
If you have a 92 prelude you dont take it to autozone because its obd1 you can just check it your self. There is a jumper wire behind your center console on the driver side, just get a wire and connect the wire and see how many times the check engine light flashes with the key turned half way and look it up or just post it and someone can tell you. now about your problem with the gasket i would get a diffrent opinion from another mechanic.
Old Jan 3, 2005 | 05:03 AM
Sabbotage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92silude &raquo;</TD></TR><TR><TD CLASS="quote">the guy that replaced the gasket said that I didn't have a fuel pressure regulator, or regulator hose...something likke that</TD></TR></TABLE>
maybe he was stating that you are missing a vacuum line from your fuel pressure regulator? just a thought
Old Jan 3, 2005 | 06:11 AM
92silude's Avatar
Default Re: lude idle problem...not like the others (Sabbotage)
yes that's what it is...there is no vacuum line...could this be my problem??
Old Jan 3, 2005 | 09:27 AM
Sabbotage's Avatar
uhm yeah id say thats probably what the problem is. put a vacuum line on there and then see if that fixes your problem. if not post back
Old Jan 4, 2005 | 04:17 PM
92silude's Avatar
alright...put a vacuum line on there..the idle didn't really go down..and I don't know about the start..I'll have to find out in the morning...and when I was looking at it, there's no hose for where the idle speed control is either...and I don't know where that's supposed to be hooked up to...and how do I check this myself again? with teh check engine light...I'm not really understanding how to do it from when preludevtec mf explained it...thanks Ryan
jeff gonzalez
10
Jun 27, 2019 10:16 AM
dystro
Jan 30, 2006 11:22 AM
bertyman
Dec 11, 2005 04:15 PM
MaWeiTao
Apr 7, 2005 06:49 AM
yoshio006
Dec 17, 2002 06:18 PM
