EGR Fooling....
Old Jan 2, 2005 | 08:12 AM
h22a193's Avatar
Default EGR Fooling....
I have the s2 IM, and cut my egr wires cause I wasent just gonna let it hang there, so how do I get the ecu, to not through a code when driving in cruising speeds, which is when it comes on? Im thinking somthing like putting a resister, there, to show thats its hooked up, because from what I have heard the wires are only there to monitor that it is actually working.... correct if wrong, thanks, I need a way around it.
Old Jan 2, 2005 | 08:55 AM
v4lu3s's Avatar
RTFM
i left the sensors on and zip tied them out of the way.
Old Jan 2, 2005 | 03:09 PM
Hawkze_2.3's Avatar
Default Re: EGR Fooling.... (h22a193)
If you're OBDI you'll be fine (no CEL) as long as it's still plugged in. I believe OBDII has a sensor that looks for flow as well as the valve movement. The only way that I know of to get rid of it a standalone...
Here's what I did with mine--
Zip ties rule--
I haven't heard about anyone using a resistor, but for you if figure it out.
Old Jan 7, 2005 | 08:53 PM
h22a193's Avatar
i guess i will just have to figure out a way and post it when I do.
CrX EnTHUSIAST
May 1, 2017 08:39 AM
kenskii
Aug 4, 2014 07:30 AM
blue_hatch
Feb 16, 2011 01:49 PM
Jonny Rocket
10
Sep 4, 2009 02:34 AM
hatch96y7
Nov 8, 2007 02:58 PM
