hood dont go down
I ****** hit a car yesterday and now my hood wont go down all the way. Everything looks fine and lined up its just the hood latch isnt working. Do i need a new one or are these easy to fix?
You can always try to beat it around with a sledge hammer or something. If it does work then buy a new one. It that latch was hit at all you're prolly not gonna be able to *easily* fix it.
when youre closing it, or attempting to do so, look under there and see what the culprit is thats hanging you up.
just have a little patience and fix it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic »</TD></TR><TR><TD CLASS="quote">
just have a little patience and fix it.</TD></TR></TABLE>
If that doesn't work, hit it with a hammer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
Hit it with a hammer first, then see what the problem is.
You might just need to adjust it. Look under while closing it.
</TD></TR></TABLE>Hit it with a hammer first, then see what the problem is.
a big enough hammer WILL fix ANYTHING
</TD></TR></TABLE>a big enough hammer WILL fix ANYTHING
there's a little lever type thingy behind the latch...kinda hard to see but if you look OVER it and down, you'll see the spring connected to it. That lever should move freely...use your finger and try to move it...if it doesn't move, you might need to pry it loose with a flat head. Hope this helps
just look at it when u going to closed it. see if is in line with the hook. if is not just hit it to what ever side it needs to be at. the hook has tu be just in the mid of it. some times if is push back after a hit the little hook doesn't open make sure is not push to hard against the metal there has to be a little gap.
i know someone who had this problem. all we did was look and see where the latched lined up on the top of the hood, and it was htiting too far left. we just hit the latch backward and it worked? Make sure everything is lined up!
Modified by hosfast at 11:03 PM 1/2/2005
I gently bumped a van a year or two ago and had the same problem. I tried to slam the hood down super hard over and over again, but nothing was latching aside from that big secondary hook.
What my culprit was was this little springy-do-dad that runs just in front of the whole assembly, just underneath everything. You just push it back with your fingers, or a pen if you have fat stubbs. It's actually part of the spring release mechanism that doesn't slide back to it's default spot. Even after oiling it, I have to make sure the spring in there is back in it's correct spot when I shut my hood.
I hope this helps.
I hope this helps.
I started this post a while ago thinking that it was my hood latch that was broken. I bought a new hood latch and same story. So now i'm thinkin my radiator support could be bent? I pushed the hood down all the way and it still doesnt go down enough to latch . Can you guys think of anything else?
Did you adjust the settings on the hood latch so it sits as high as it can? If so...when you hit the car your radiator support could have bent down just a little bit. Look at all the body lines to see if there are any indications that this could have happened. The body line where the bumper cover and the fenders line up would be able to show you. You might not be able to tell by eye if the core support is bent but it could be just a little bit. You could even try pulling it up with your hands, that might give you another 1/4" to a 1/2".
Good luck.
Good luck.
ek4h
54
Nov 15, 2006 09:28 PM
