Hood Latch Suxors
Old Jan 1, 2005 | 07:26 PM
fw190bvi's Avatar
Default Hood Latch Suxors
my hood latch has been a pain in the *** for sometime, and now its getting worse....ive already power washed it a few times, and regreased stuff...though i havent removed the mechanism from the car, ive done it all with it still attached....basically, it wont catch when closing the hood, no matter how much or how little effort you put into it....in addition, it seems as though theres extra slack in the cable, as the release is REALLY loose once the hood is open.....im just wondering if anyone else has had this problem, and any easy, if any solutions, short of new latch and running new cable (not sure how hard that would be)
TIA
Old Jan 1, 2005 | 07:35 PM
JDM.Accord's Avatar
Default Re: Hood Latch Suxors (fw190bvi)
Hood pins y0 Prolly the cheapest solution, if not the best
Old Jan 1, 2005 | 07:39 PM
fw190bvi's Avatar
Default Re: Hood Latch Suxors (JDMAccord2nr)
hood pins diffently arent my style.....
Old Jan 1, 2005 | 07:52 PM
jb.'s Avatar
jb.
i have this problem but worse, and when i open the hood, i have to manually push the piece back so it will lock. the body shop i go to said that it would have to get a new latch because once it stops working, you will have to cut a hole in the hood to get it off.
Old Jan 1, 2005 | 08:04 PM
SlammedCD7's Avatar
Default Re: Hood Latch Suxors (jbkiksass69)
this has recently started happening to me, it opens fine, but it just wont close, even if you lay it on the latch and try to push down to close it, it wont lock, i have to drop it from several different heights around 10 times to have it finally close
Old Jan 1, 2005 | 08:06 PM
iLUVmyACCORD's Avatar
this has happened to me too... u gotta replace the cable and that should be it..
Old Jan 1, 2005 | 08:18 PM
fw190bvi's Avatar
Default Re: (AccOrd-fiZZle)
what does that intale, and how hard is it?
FritschDog
22
Mar 31, 2017 08:41 AM
TypeRod
Sep 4, 2010 11:33 AM
miguey310
Jun 21, 2010 07:38 PM
green98civic
Mar 16, 2003 01:23 PM
