idling not properly when start the engine
i bought a used s2000
and its got few mod in it
its got Mugen Header,ARC exhaust
but i duuno if the guy change the ECU or not or CAM
heres the problem,every time when i start the engine,the RPM seems like drop a lot and almost stall the car and goes back up again
what kinda problem could it be?and is that normal?thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant »</TD></TR><TR><TD CLASS="quote">try resetting the ECU but what rpm's is it dropping to? like whats the lowest it drops to and then when it fluctuate</TD></TR></TABLE>
hm...the rpm drops to like 200-300 i think
u can feel the car shaking like almost stalling
how do i reset the ecu?
That's what happened to mine a month ago. It's in the shop and we're still trying to figure out the cause. So far we've checked the IAC, mostly all of the sensors, checked if there was a vacuum leak, etc. The only thing I can think about is probably a bad ecu or the TPS sensor. I'm through with fiddling around with it so I just sent it to a local honda dealer to see if they can figure out it. Hopefully they can because I can't stand not having my s2000 anymore.
v8killaz
Honda Civic (2001 - 2005)
13
Sep 11, 2008 03:33 PM
