is this fixable?
Old Jan 1, 2005 | 11:36 AM
Turbo-charged's Avatar
Default is this fixable?
dont ask me why...but a guy i know tried to take the collector apart...and it wont go back together? will heat help? any sugestions? no hammering it wont make it move A N Y
Old Jan 1, 2005 | 11:56 AM
loseneon's Avatar
You need a torch. Torch the upper part so it expands and then use force of some sort to shove it back into place. Thats the only way i would think it could be done.
Id also shoot some liquid wrench in there and let it soak just for added assistance.
Old Jan 1, 2005 | 11:57 AM
Jared's Avatar
Default Re: is this fixable? (Turbo-charged)
lay the female collector end on a hot plate and walk away, let it bake for 10mins or so, come back and shove the male part in and let it cool.
Old Jan 1, 2005 | 02:25 PM
RCautoworks's Avatar
Default Re: is this fixable? (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">lay the female collector end on a hot plate and walk away, let it bake for 10mins or so, come back and shove the male part in and let it cool.</TD></TR></TABLE>
A hot plate will really get it that hot ? Hmm
Old Jan 1, 2005 | 06:59 PM
snoochtodanooch's Avatar
or grab some liquid nitrogen and pour it on the male end.....
Old Jan 1, 2005 | 10:01 PM
cjames235's Avatar
Default Re: is this fixable? (snoochtodanooch)
haha or do both..... put the male end in a deep freezer for a day or so then heat up the female end....... that combo should get it back together pretty easily
Old Jan 2, 2005 | 12:33 AM
.RTErnie's Avatar
Default Re: is this fixable? (cjames235)
dont forget the lube. you wouldn't screw your GF in the *** w/out lube would you? You have to think...you're putting something hard in a tight spot
Old Jan 2, 2005 | 02:34 PM
LostCRX's Avatar
Default Re: is this fixable? (Matt_sb2004)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt_sb2004 &raquo;</TD></TR><TR><TD CLASS="quote">...you're putting something hard in a tight spot...</TD></TR></TABLE>
For some unknow reason I have a mental picture that totally NOT related to automotive at all!
Old Jan 2, 2005 | 03:26 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
or spit on it. think i saw it in a movie once.
Old Jan 2, 2005 | 03:28 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: is this fixable? (not so civic)
best thing ever, astroglide
Old Jan 2, 2005 | 03:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not so civic &raquo;</TD></TR><TR><TD CLASS="quote">or spit on it. think i saw it in a movie once.</TD></TR></TABLE>
LOL
Old Jan 2, 2005 | 07:43 PM
kid-honda's Avatar
HAHAHA I think I did to, atleast it worked for jenna haze
Old Jan 2, 2005 | 07:56 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: is this fixable? (kid-honda)
jenna haze = major hottie. you have no idea what i would do to her if i got the chance
Old Jan 2, 2005 | 09:07 PM
JDMorgan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">or grab some liquid nitrogen and pour it on the male end..... </TD></TR></TABLE>
that would suck.
Old Jan 2, 2005 | 10:00 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
place a ratchet strap around the whole assembly.. spray lube the joint.. bernzomatic torch on female and cold wet rag on male.. keep cranking ratchet strap while whacking with plastic mallet.
thats a really good design by the way. hytech copy.
Old Jan 3, 2005 | 07:52 PM
.dave's Avatar
i HAS questions ?
Default Re: (mike_belben@yahoo.com)
You could also spray CO2 from a paintball tank or even spray some nitrous on the male end to cool it. Theres a picture in a recent issue of Hot Rod with some guys using nitrous to cool a part for a similar situation.
By the way, is that a Hytech manifold?
Old Jan 3, 2005 | 08:06 PM
kid-honda's Avatar
Default Re: is this fixable? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">jenna haze = major hottie. you have no idea what i would do to her if i got the chance </TD></TR></TABLE>
I know what i do to myself when I see her
And to stay on topic what manifold is that?
Old Jan 3, 2005 | 09:29 PM
KFMRC's Avatar
if your having a difficult time getting all the tubes lined up the easiest way is to cut about 1/4 off of one tube and 3/8 off of another. This will allow you to get 2 tubes started then the third and finally the fourth instead of trying to fight with all of them at once. It will not affect the tuned length and will make it easy to assemble. Use some wd-40 or some crc lubricant and things should go together easily. if you need to tap the collector on then use a block of wood or a dead blow hammer.
I stagger the header tubes on all the headers I build and it makes things much more friendly.
good luck
bob kasper
kfm race cars & components
609-851-2810
Old Jan 4, 2005 | 05:08 PM
Default Re: is this fixable? (KFMRC)
thanks for hte help guys. i have like a million lb. bottle of nitrous that i NEVER use....maybe ill freeze a bunch of stuff and throw it int he parking lot and watch it explode! and a torch. seems like with all the options you have listed i should be able to figure out something.
its not a hytech manifold, its one we made very similiar...just a one-off....for a customer/frineds car. i didnt do any of the welding on this one. car made 450whp on 93 octane about 3 years ago...when that was unbeleivable
Old Jan 5, 2005 | 05:14 PM
matt_sb2000's Avatar
BAWHAHAHAHAHAHAHA
ek_ctr
Dec 30, 2006 11:14 PM
Lethalb18c1
Dec 12, 2006 10:57 PM
NOPIDRAGS
Jul 28, 2006 11:54 PM
fullblown
Welding / Fabrication
Jan 11, 2005 07:41 PM
ITRFetish2000
May 14, 2004 10:42 AM
