locked keys in car..
no spare key is just asking for this to happen. but if you have a slim jim, that will do the trick. if you call the locksmith, he'll be there for like 1min, open your door, and collect.
grab the registration (VIN #) + your driver license...run to your local acura dealership..and they make you a spare key for $5 plus alittle tax.....problem solved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrfrancisco »</TD></TR><TR><TD CLASS="quote">dude just pull the window outta the seal and unlock the door</TD></TR></TABLE>
the integra has that little round pin thing...
find someone(parent, friend etc.) with AAA call up the locksmith guy and they'll open it for u for free...
remember if you mess up your car you pay.. if he messes up your car.. he'll pay..
but chances are he's probably a pro at opening cars up...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SonicBlueTeg »</TD></TR><TR><TD CLASS="quote">find someone(parent, friend etc.) with AAA call up the locksmith guy and they'll open it for u for free...
but chances are he's probably a pro at opening cars up...</TD></TR></TABLE>
half the time, you have to sign a waver anyways.
seriously, call your local police department, they will probably help you out
but chances are he's probably a pro at opening cars up...</TD></TR></TABLE>half the time, you have to sign a waver anyways.
use a screwdriver to pry the window out and use the coat hanger to hit the power door lock button ... i do this all the time at work when customers lock their keys in their car with a alarm ... kinda scares the coustomers to see how fast i can get in their car
best thing to do is get a piece of something like rubber and take a flathead screwdriver and pry the door open on the top trying to not mess up the weather stripping. while you have this pryed slightly use a coat hanger with a loop to pull the trunk latch up. easiest way when losing keys..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kikwear002 »</TD></TR><TR><TD CLASS="quote">best thing to do is get a piece of something like rubber and take a flathead screwdriver and pry the door open on the top trying to not mess up the weather stripping. while you have this pryed slightly use a coat hanger with a loop to pull the trunk latch up. easiest way when losing keys..
isnt that what i just had posted?????????
</TD></TR></TABLE>isnt that what i just had posted?????????
don't use a screw driver you'll probably break the window, just usea little bit of thought and you can get the hanger through the rubber seam with out a screw driver i've done it before...
Wow, I remember when this happened to me. I was up at an ex-g/f's house and locked the keys in the car, it sucked so bad. I just went up to a neighbor's house and asked politely if they had anything I could try to get into my car with. Came back w/ a flathead, a scredriver, and a metal ruler. I never got it though, and ended up messing up my tint by pulling the window out. If you use a screwdriver (or crowbar) to pry on the window, wrap it in something like a towel. From there you should be able just to get the door lock w/ a hanger like everyone has said. It's more flexible than you think.
gl!
gl!
Same thing happened to me yesterday. I went out to the car. Opened the passenger door, put my son in his car seat, closed the door, walked around to the drivers side and the doors were locked. WFT?! Pop-A-Lock opened it up for free b/c he was in the car but normally they charge $30.
killaj12
15
Mar 10, 2005 07:02 PM
kryzeofkrayzie
Jun 10, 2002 04:59 PM
