Type S tranny.... How to tell?
Ok im going to be looking at a tranny tonight and its suppose to be a typseS LSD tranny. How can i tell IF in fact it is an actual type S other than the little code? I really dont want to get screwed on this deal.......
BTW is there any way to tell if it has LSD and if its stock?
Thanks for the help in advance!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enigma94 »</TD></TR><TR><TD CLASS="quote">
If you can see straight through the tranny where the axles go through,
then it's LSD.
</TD></TR></TABLE>If you can see straight through the tranny where the axles go through,
then it's LSD.
If i CAN see through it or CANT?
I am talking about the typeS with LSD. I own a civic with a h22 in it so im not up on all the prelude stuff, so im pretty sure thats what its called.....
Check this thread, Keith provided a good pick that will help you figure it out.
https://honda-tech.com/zerothread?id=1062939
Basically if it's an LSD you won't see a spindle/bar going across the center. Instead you'll be able to see right through it.
correct...the Type S has ATTS diff attached to the block and has a different trans than the SIR S spec that has the LSD trans. And you can see straight threw, no visible shaft on BOTH trans so you have to go by the codes or know the slight differences between the ATTS/LSD set ups
b18avtec(A!!M0TOR)
Jan 29, 2007 03:22 PM
Tuan
Jul 8, 2002 10:57 AM
