several hours later...
first time i've done a tranny, by myself, using hand tools... so it's taken me awhile...
the other day, i couldn't shift my car into gear when the motor was on, only off. limped it home in second gear.
luckily, i had already bought an itr tranny, new clutch, and new flywheel, so i wasn't too distraught...
here's a picture of the culprit:
~40k of use. improper break-in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">The chunk missing off your clutch?</TD></TR></TABLE>
looks like there is a hole parallel to the spring that is scraped
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic »</TD></TR><TR><TD CLASS="quote">the spring retainer broke out. then the spring hung up.... mine did the same thing...
EXEDY was next for me
That *is* an exedy.
</TD></TR></TABLE>That *is* an exedy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC »</TD></TR><TR><TD CLASS="quote">That *is* an exedy.
correction.. that was an exedy
</TD></TR></TABLE>correction.. that was an exedy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">THAT IS NOT impropper breakin!!!!!
What do you think it is?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">THAT IS NOT impropper breakin!!!!!</TD></TR></TABLE>
well, i broke it in by driving about 50 miles on the highway then i went drag racing on it.
whether or not that's why it died at 40k miles, i don't know.
i think what he is trying to say is that improper break in might cause the the clutch to slip or maybe not last as long but it definately wont make a hole in the clutch.
Did you miss a gear when this happened?
I agree. There's no magic coating on a clutch that takes 1,000 miles of easy driving to go away. You improperly break in a clutch by glazing it with high rpm launches and bad driving. It's hard to damage a clutch in the first 50 miles and have the effects show themselves 40,000 miles later.
Same thing with breaking in internals. If they aren't working properly in the first couple seconds after startup, something was done wrong during installation and the damage is already done. Yeah, you need to let rings seat and oil pressure settle before revving the **** out of something, but - again - there's no magic about 1,000 miles of easy driving that's going to drastically effect the longevity of a properly-assembled rotating assembly.
2000blksi
Transmission & Drivetrain
Mar 11, 2014 09:05 AM
le0ftw
Oct 7, 2008 07:19 PM
