timing asap
i need to know asap what timing mark on hte skunk 2 cam gears line up and face eachother for a b series integra vtec motor . there are 3 marks and im not sure which ones line up
Here is the easy way , take too small screwdrivers or dowel pins and rotate the cams around untill the holes in the cam plates line up with the hole in each cam, then both of them should be ready to have the TB installed. Just remeber if you feel hesitation like valves running into eachother stop and rotate the other cam around. You can also take a look at the cam gears the adjustment marks should both be at the top in the 12 oclock position
JDMs1eeper
Aug 20, 2003 09:15 AM
