Anyone using test pipes?
Old Dec 31, 2004 | 05:34 PM
GSRerrr's Avatar
Default Anyone using test pipes?
hey im deciding if i should get a test pipe or (CAT-LESS), i just wana know how it sounds and if there are noticiable gains thanks guys.
Old Dec 31, 2004 | 06:25 PM
PLAGUED_DB7's Avatar
Default Re: Anyone using test pipes? (GSRerrr)
had one, no that big of gain only sound..loud as fawk on the apexi
N1..I took it off for that reason
Old Dec 31, 2004 | 06:43 PM
Riake's Avatar
I could feel a difference in both sound and power with a test pipe. I had a slight bump in torque down low with stock, but with the pipe i have a bigger than slight bump at the high end. however it will eventually make your exhaust raspier, faster than with a stock cat.
high end
a lot louder, more low end with stocker
eventually a raspy exhaust
Old Dec 31, 2004 | 06:54 PM
Moogen Powah's Avatar
Default Re: Anyone using test pipes? (Riake)
Also consider your location before purchasing a test pipe. Using a test pipe, in the place of a cat, will more than likely not allow you to pass smog.
Old Dec 31, 2004 | 07:01 PM
Danziver's Avatar
In my opinion you should get a high flow cat, i have a carsound and i enjoy it much more than my old test pipe. It sounds better and the exaust doesn't stink.
Old Dec 31, 2004 | 08:24 PM
vart's Avatar
Default Re: Anyone using test pipes? (Moogen Powah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moogen Powah &raquo;</TD></TR><TR><TD CLASS="quote">Also consider your location before purchasing a test pipe. Using a test pipe, in the place of a cat, will more than likely not allow you to pass smog.</TD></TR></TABLE>
glad i dont have smog tests
Old Dec 31, 2004 | 08:44 PM
svtec's Avatar
L D E S
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riake &raquo;</TD></TR><TR><TD CLASS="quote">I could feel a difference in both sound and power with a test pipe. I had a slight bump in torque down low with stock, but with the pipe i have a bigger than slight bump at the high end. however it will eventually make your exhaust raspier, faster than with a stock cat.
high end
eventually a raspy exhaust</TD></TR></TABLE>
this is all true. i am trading mine out for a stock cat because it is raspier than all hell.
Old Jan 1, 2005 | 02:18 AM
GSRerrr's Avatar
Default Re: Anyone using test pipes? (svtec)
thanks everyone
Old Jan 1, 2005 | 08:31 AM
FULL-REV's Avatar
I have a test pipe and it helped my engine out alot. My engine felt like it was choking when the cat was in place. When in installed the testpipe i felt a gain and the cars throttle respones increased. Great mod if you ask me... its cheap to. I have it on a Skunk2 Mega power and let me tell you when i'm at WOT the car screams like crazy!
Old Jan 1, 2005 | 10:28 AM
AlxSiR7's Avatar
test pipes arent really for naturally aspirated engines.. there needs to be some back pressure. test pipe all the way for forced induction though
Old Jan 1, 2005 | 11:12 AM
mingbling96's Avatar
Default Re: Anyone using test pipes? (AlxSiR7)
don't be ghey.
Old Jan 2, 2005 | 12:27 AM
svtec's Avatar
L D E S
Default Re: Anyone using test pipes? (mingbling96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingbling96 &raquo;</TD></TR><TR><TD CLASS="quote">don't be ghey. </TD></TR></TABLE>
you're an idiot.
y2kferari
Dec 11, 2009 05:22 AM
EG type GTR
Jul 9, 2006 05:28 PM
mugenspoongsr
Aug 22, 2005 02:04 AM
mkpl99
Apr 9, 2003 07:05 PM
Blue-Civic-Hybrid
12
Apr 11, 2002 04:39 PM
