timing asap
Old Dec 31, 2004 | 11:50 AM
elusive123's Avatar
Default timing asap
i need to know asap what timing mark on hte skunk 2 cam gears line up and face eachother for a b series integra vtec motor . there are 3 marks and im not sure which ones line up
Old Jan 2, 2005 | 12:04 AM
gt30typer's Avatar
Default Re: timing asap (elusive123)
Here is the easy way , take too small screwdrivers or dowel pins and rotate the cams around untill the holes in the cam plates line up with the hole in each cam, then both of them should be ready to have the TB installed. Just remeber if you feel hesitation like valves running into eachother stop and rotate the other cam around. You can also take a look at the cam gears the adjustment marks should both be at the top in the 12 oclock position
JBLAZE622
Jun 3, 2010 03:32 AM
doublejz
Oct 23, 2003 02:43 PM
JDMs1eeper
Aug 20, 2003 09:15 AM
