(((Need Help))) Headlights wires been cut.
Old Dec 31, 2004 | 06:09 AM
slowls's Avatar
Default (((Need Help))) Headlights wires been cut.
All my wires has been cut. I mean everything: 9006, 9005, and corner lamps. Stupid thieve couldn't just take the lamps but they had to cut everything.
I need help in identifying the wires. Does anyone know how to do this?
Thanks in advance
Old Dec 31, 2004 | 06:29 AM
Racermech's Avatar
Default Re: (((Need Help))) Headlights wires been cut. (slowls)
Wiring diagram. Maybe in a helms book. I have one at home, but i wont be there for a while and i wont be back on my computer till later tonight. But i will grab it incase you still need it
Old Dec 31, 2004 | 11:32 AM
slowls's Avatar
Thanks Racermech,
Let me know if it's in the Helms.
I would like to buy the male and female socket for the 9006,9005, and corner lamps. Does anyone know where I could get one used?Already tried the junkyard. No LUCK. I'll post in the Classified later on.
Old Dec 31, 2004 | 03:12 PM
calxtreme's Avatar
you can also you a multimeter to test the wire for voltage.
Old Jan 1, 2005 | 05:17 AM
EnjoyTheRideDC2's Avatar
Drivers side (+) : Low Beam = Red/yellow
High Beam = Red/green
Passenger Side (+) : Low Beam = Red/white
High Beam = Red/blue
Ground wire for all 4 are black colored wires. They should be right next to these wires.
If you need a cheaper alternative to 9005 and 9006 OEM plugs, run down to pep boys or Autozone and pick the headlight sockets there. about 5 bucks each.
Conduct-Tite Headlight Sockets - #85813=9006 connector, #85812=9005 connector
Mixmasta
Jan 27, 2009 05:32 PM
kmfdmww3
Aug 18, 2007 04:53 PM
d16civic111
Jul 11, 2006 01:02 PM
HatchUnit187
Sep 10, 2003 09:12 AM
beginnerCivic
Audio / Security / Video
Sep 9, 2003 05:10 AM
