tire width question....
Old Dec 30, 2004 | 11:55 PM
Dumped DB2's Avatar
Default tire width question....
I recently bought a set of rota grids from a friend of mine about 2-3 months ago and 2 tires are good, and 2 tires have very bad camber wear. they are 16x7 and I wanted to know if it was safe to run the Falken Azenis sports in 215/45-16. I know most people run 205's, but the only other azenis that fits 16's are 205/50-16, but i want to stay with 45 series to match my back two tires....so will i have any probs with the 215 over the 205's?
Old Dec 31, 2004 | 12:30 AM
importdude2000's Avatar
should fit
might rub tho
Old Dec 31, 2004 | 06:28 AM
..::91TEG-G2::..'s Avatar
Default Re: tire width question.... (Pjct2ndGenTeg)
lowered any? if so, how many inches?
Old Jan 1, 2005 | 10:13 PM
Dumped DB2's Avatar
Default Re: tire width question.... (..::91TEG-G2::..)
about 1.8 all around. im only gettin 2 of the falken's though because the back 2 tires are fine and these falkens will be going on the front
Old Jan 1, 2005 | 10:31 PM
Dumped DB2's Avatar
anyone else know for sure?
Old Jan 1, 2005 | 10:45 PM
you might be fine if you have stiff spring rates and your shocks/struts on like 3/4/5 if there adjustable
Old Jan 1, 2005 | 10:51 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I think there are quite a few who run 215/45 Azenis in the ITR forum.
But I personally would get a matched set of 4. Staggered tire widths AND diameters might create some pretty squirelly handling characteristics.
Old Jan 1, 2005 | 11:12 PM
au-gsr's Avatar
we run 215 45 15's on ssr comps with no rubbing at the autoo x events. those cars are loered extremely and have lots of camber though. don't know if that helps but i think you'll be fine w/ a proper alignment
Old Jan 2, 2005 | 07:33 AM
Default Re: (au-gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by au-gsr &raquo;</TD></TR><TR><TD CLASS="quote">we run 215 45 15's on ssr comps with no rubbing at the autoo x events. those cars are loered extremely and have lots of camber though. don't know if that helps but i think you'll be fine w/ a proper alignment</TD></TR></TABLE>
yeah that does help alot. because your tires arent lined up exactly with the top/edge of the fender so it doesnt rub because the tire is going at an angle inside the fender..
Old Jan 2, 2005 | 09:13 AM
Dumped DB2's Avatar
Default Re: (..::91TEG-G2::..)
heres a pic of my car as it sits on the 16x7 rotas....
Old Jan 2, 2005 | 07:42 PM
Community Builder
215/45-15 is alot different than 215/45-16, i.e. a whole inch in diameter difference.
TheMuffinMan
Sep 16, 2008 10:42 AM
sprayedlude93
Mar 9, 2006 03:46 PM
Dumped DB2
Jan 6, 2005 09:17 PM
MisterB18c5
Aug 12, 2004 07:49 PM
jared703
Oct 16, 2001 01:03 PM
