Radiator Overflow on Boosted Teg Help 347whp...??
Old Dec 30, 2004 | 10:21 PM
shiftinPastU2's Avatar
Default Radiator Overflow on Boosted Teg Help 347whp...??
If anyone could help me out it would be great…
Specs:
I have a boosted LS/Vtec with JE pistons Eagle rods a block guard
ARP head studs torque16 ftlb and Cosmetic Head Gasket
The car is running on 15-16 psi under hondata engine management, 347 whp
The problem is under boost pressure the stock radiator builds up pressure enough so that the overflow can overflows with fluid only under boost. Immediately the head gasket was suspected to be the problem but its fine no coolant in the oil, the car never over heats. The thermostat was removed, and I replaced the radiator cap with a new one, however pressure still build up to the point where it is overflowing the radiator catch can.
Any suggestions or help would be greatly appreciated…
Thanx
Old Dec 30, 2004 | 10:23 PM
b16hybridsol's Avatar
Default Re: Radiator Overflow on Boosted Teg Help 347whp...?? (shiftinPastU2)
headgasket
Old Dec 30, 2004 | 10:36 PM
Aggressive Racing's Avatar
First of all it's COMETIC not cosmetics.
second what do you mean torqued 16 ft lbs,youshould go 75.
third there doesnt necessarily have to be coolant in the oil,it is definitly your head gasket!
Old Dec 30, 2004 | 11:27 PM
W O T's Avatar
Default Re: Radiator Overflow on Boosted Teg Help 347whp...?? (aggressivemotorsports)
Are you serious about the 16 ft/lbs for the headstuds? Man thats like ******* hand tight. Id assume thats what cause your bigger problems you now have
maddcrx
Honda S2000
Jun 7, 2008 10:03 PM
shiftinPastU2
Dec 30, 2004 09:30 AM
B17AGSR
Jun 8, 2004 07:23 AM
CRXSIR1
Jan 12, 2003 05:53 PM
