Help Me Just got my peak boost kit !!!!!!!!
Ok here are my problems when i get the turbo lines up to meet with the intercooler pipe the oil return line is pointing straight up so how do i move that so its down becuz the line will never reach...i looseden the outside bolts to move to the turbo to where it needed to be but how do i get the oil reutrn part down..Here is a pic of what iam talking about....And also where do i tee in for my blow off valve and my boost gauge?????
And how the hell is my front bumper going to fit with fog lights i tried it and its no where close hose do i go about doing that
Re: Help Me Just got my peak boost kit !!!!!!!! (ebpcivicsi1234)
you have got to loosen the bolts that hold the back plate and compressor cover clock the center section first then clock the compressor cover
there bolts that hold the turbineside to the actualcartrdige wher your oil feed and drain are theyy should be 1/2 bolts shold be 6 of them loosen them out and rotate it where you want it then tighten hem back up and make sure you did drop any of bronze/silver flat things
Re: Help Me Just got my peak boost kit !!!!!!!! (braintree)
WHY!?
Why would you loosen the lower ones in the pic? Why not just the ones holding the compressor down, tap it up, spin it and tighten it back down?
WHY!?
Re: Help Me Just got my peak boost kit !!!!!!!! (W O T)
becuz you cant rotate the cartridge to face down unless you loosen the turbine side the compressor side is the easy side to do
Exactly. The oil section in the middle is connected to both the compressor and the exhaust side. You have to loosen BOTH to rotate the middle section.
(******* retarded)
I was talking about just rotating the compressor housing
You guys are correct
Had it stuck in my mind beause I just rotated mine last night to fab charge pipes, got that in my head lol instead of oil return
So i need to loosen both in the pics correct And also shouldnt there be a gastet for my oil fitting thats in the pic that goes to the turbo and shouldnt there be a gasket bewteen the manifold and the turbo i recieved none
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebpcivicsi1234 »</TD></TR><TR><TD CLASS="quote">shouldnt there be a gasket bewteen the manifold and the turbo i recieved none</TD></TR></TABLE>
You don't need it.
You don't need it.
Re: Help Me Just got my peak boost kit !!!!!!!! (11psiTurboSI)
ok but what about a gasket bewteen the turbo and the oil plate,fitting that they gave me that is in the first pic?? also where to i hook up my boost gauge and blow off valve too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebpcivicsi1234 »</TD></TR><TR><TD CLASS="quote">ok but what about a gasket bewteen the turbo and the oil plate,fitting that they gave me that is in the first pic??</TD></TR></TABLE>
You indeed need that gasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebpcivicsi1234 »</TD></TR><TR><TD CLASS="quote">ok but what about a gasket bewteen the turbo and the oil plate,fitting that they gave me that is in the first pic?? also where to i hook up my boost gauge and blow off valve too</TD></TR></TABLE>
i apologize if you didnt receive the gasket kit with your turbo system.
give me a call at the shop first thing monday morning, and i will have one nextday'd to you. 1-877-23-turbo
thanks again for your purchase, and feel free to give us a call for any other installation questions.
installation guide coming very soon.
happy holidays
ken
happy holidays
ken
Re: Help Me Just got my peak boost kit !!!!!!!! (CHEAPTURBOdotCOM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEAPTURBOdotCOM »</TD></TR><TR><TD CLASS="quote">
happy holidays
ken</TD></TR></TABLE>
A++++ for customer service. . .
happy holidays
happy holidays
Hell yes.. great to see this customer service!
happy holidays
H-T White Ops
If you need to have a gasket ASAP you can always go down to your local auto parts store and buy a piece of gasket material and make your own with an exacto knife.
Good looking out by Ken though.
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI »</TD></TR><TR><TD CLASS="quote">
You don't need it.</TD></TR></TABLE>
it's a good idea, believe it... use it
Re: Help Me Just got my peak boost kit !!!!!!!! (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T »</TD></TR><TR><TD CLASS="quote">what gasket are you guys talking about</TD></TR></TABLE>
someone isnt reading...the gasket between the oil return flange and the cartridge..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">
it's a good idea, believe it... use it</TD></TR></TABLE>
u dont NEED it if the two surfaces are flat..
Re: Help Me Just got my peak boost kit !!!!!!!! (eg6T)
When I used a gasket on the T3 flange it started falling apart (not from these guys but I'm sure they're all pretty much the same).
Took it out afterwards, never had a problem!
