throttle response once again
Old Dec 30, 2004 | 07:56 PM
handa's Avatar
Default throttle response once again
i'm continuing to hunt this throttle response problem with my b16. if you've read my past threads, there were many posts concerning throttle response.
anyway, i thought my stock catalytic converter was causing it, so today, i drilled and gutted it all out. still no luck, but just better rev speed. throttle is still bad around the 1000-2500 rpm. this gets annoying when i daily drive the car because throttle is not instant and it feels all squishy on the pedal. i have no CEL whatsoever. it's a stock b16aII and i have 2.25" piping all the way through.
would adjusting the idle screw make it better? is 3" intake piping too big? i'm stumped.
Old Dec 30, 2004 | 08:09 PM
areyoujealous's Avatar
Default Re: throttle response once again (handa)
If you didn't have a CEL before, you will now with your hollow cat.
Check the throttle body itself. Sometimes the oil vapors from your valve cover will be sucked in and you will have sludge on the throttle plate. Carb cleaner works beautifully.
Also check your throttle cable. Maybe it's loose.
Old Dec 30, 2004 | 08:11 PM
eK9aT10pSi's Avatar
did you set the idle per the helms manual? turn everything off, disconnect the iavc plug, idle should drop to like 550rpm [pretty sure, but dont have my helms in front of me] + or - 50rpms . thats to set your base idle.
Old Dec 30, 2004 | 08:20 PM
doublejz's Avatar
Default Re: throttle response once again (eK9aT10pSi)
have you tried doing a maintance job on it. plugs, wires, rotor, cap? Fuel injector cleaner, fuel filter? I would avoid touching the idle screw if you dont have to.
Old Dec 30, 2004 | 08:21 PM
handa's Avatar
Default Re: throttle response once again (areyoujealous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by areyoujealous &raquo;</TD></TR><TR><TD CLASS="quote">If you didn't have a CEL before, you will now with your hollow cat.
nope i gunned it couple of times tonight, and no CEL. hmm throttle body was dirty with black sludges...i'll clean it out soon. throttle cable...i'm sure it's tight.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi &raquo;</TD></TR><TR><TD CLASS="quote">did you set the idle per the helms manual? turn everything off, disconnect the iavc plug, idle should drop to like 550rpm [pretty sure, but dont have my helms in front of me] + or - 50rpms . thats to set your base idle.</TD></TR></TABLE>
i'll give that a try tomorrow.
Old Dec 31, 2004 | 12:30 PM
crazy eyez killa
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa &raquo;</TD></TR><TR><TD CLASS="quote">
nope i gunned it couple of times tonight, and no CEL. </TD></TR></TABLE>
hahahah you wait and see it will turn on every couple of days.
To turn it back off, reset the ECU by unplugging your battery for 10 minutes.
To turn it off permanently, go OBD1 ecu.
Old Jan 1, 2005 | 01:28 AM
handa's Avatar
Default Re: throttle response once again (YOUR MAMA)
i tried messing with the IACV using eK9aT10pSi's method.
i warmed up my car, let it idle to around 700rpm, turned off the car, unplugged the IACV plug, turned on the car again, and the motor revved up to 4000rpm and dropped instantly and died. it was supposed to drop to around 550 rpm right? the only way i can make the motor steady and alive is to push on the pedal a little.
am i doing this right? this throttle response problem is !$#!@$#@ annoying...ever since i swapped it back in may 2004! the motor checked in at 215psi all across, new distributor from Distributor King, set at TDC and timed 16 deg, new oil change, and my throttle cable is tight as a *****. any help would be hot!
Old Jan 1, 2005 | 01:43 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa &raquo;</TD></TR><TR><TD CLASS="quote">is 3" intake piping too big?</TD></TR></TABLE>
Have you tried using a stock intake and airbox at all?
CAIs tend to cause poor throttle response.
Old Jan 1, 2005 | 01:52 AM
handa's Avatar
Default Re: throttle response once again (Targa250R)
i have a short ram with K&N filter, and i've tried using NO intake also. both methods result the same response.
jksmith
Feb 19, 2009 09:39 AM
pohaku
Oct 1, 2007 01:04 PM
LSVTEC 91 Civic
15
Oct 28, 2005 06:16 PM
mkinpwrat12g's
Sep 1, 2005 07:12 AM
frostcivic
Oct 12, 2004 03:52 AM
