4 bolt ITR swap problem
Old Dec 30, 2004 | 09:25 AM
Atomic EG's Avatar
Default 4 bolt ITR swap problem
Hey people i know there is a large amount of knowledge out there on this topic but i have a specific question.... I have this swap done and i have a soft brake pedal....do i need to change the master and booster?
Old Dec 30, 2004 | 09:34 AM
mrlegoman's Avatar
Default Re: 4 bolt ITR swap problem (Atomic EG)
bleed your brakes again. then bleed some more. then bleed some more.
fyi: get some cheap-o brake fluid and run a whole bottle through. Then have some super-blue or equivalent 'good' fluid and bleed until you see the good stuff come through.
It it common after a brake swap for pockets of air to be trapped in the m.s.
There are a lot of different methods used. A Search should pull up a bunch of them.
Old Dec 30, 2004 | 01:04 PM
PABLOHONDA's Avatar
Default Re: 4 bolt ITR swap problem (mrlegoman)
RIGHT-- SOMETIMES YOU HAVE TO RUN A BOTTLE OR TWO AND PUMP THE **** OUT OF IT JUST TO GET THE AIR OUT
Old Dec 30, 2004 | 01:09 PM
=GAME='s Avatar
are you still using the stock m/c? if so try upgrading to a larger m/c.
better yet, find a mc/bb combo from a non abs integra at the junk yard and youll be set.
c|rop3asy==[]
15
Jun 22, 2011 12:54 PM
modulo_s
Honda Motorcycles
19
May 12, 2008 12:20 PM
kpop
Jan 31, 2007 04:44 PM
Hackbackb18c1
Apr 20, 2005 08:03 AM
lo0nY
28
Jan 26, 2005 09:54 AM
