hidden costs for rear disk brakes
Old Dec 30, 2004 | 03:46 AM
kysard's Avatar
Default hidden costs for rear disk brakes
Used trailing arm assembly - $250
trailing arm bushing - $100
Brembo blanks - $60
Pads - $50
New hub/bearings - $200
Total - $660 and hope that the used caliper is good
I just can't see that this is worth it? Is there a better (cheaper) way?
Old Dec 30, 2004 | 03:47 AM
ki3t's Avatar
This user can set his title.
Default Re: hidden costs for rear disk brakes (kysard)
Yeah, Find a wrecked integra from a junk yard and get mostly everything off of it.
Should be way cheaper
Old Dec 30, 2004 | 04:03 AM
civic-4-ges's Avatar
You are planning what most would not. I think most that would do this swap would just cheap out and get OEM replacement pads, and just turn the discs. I would not imagine most worrying about any bearings either.
However good thinking
Worth it? Well.... I guess it depends on where you want to go on the future
Old Dec 30, 2004 | 07:44 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: hidden costs for rear disk brakes (civic-4-ges)
If you buy from import auto salvage, they guarantee everything to work except rotors & pads. Here is my link to rear disc swaps. It has a lot of good info, and all the prices of the materials I used. If you read everything, you will be very prepared for this swap...
https://honda-tech.com/zerothread?id=1036267
Old Dec 30, 2004 | 07:59 AM
skunk2eg's Avatar
Default Re: hidden costs for rear disk brakes (94eg!)
being as the front brakes do most of the work.... i'ts not worth it to get upgrades rear disks being light as civics are...just my 0.02
Old Dec 30, 2004 | 08:32 AM
Mike_C's Avatar
Default Re: hidden costs for rear disk brakes (skunk2eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2eg &raquo;</TD></TR><TR><TD CLASS="quote">being as the front brakes do most of the work.... i'ts not worth it to get upgrades rear disks being light as civics are...just my 0.02</TD></TR></TABLE>
unless your drums are busted and you regularly track your car (change pad compounds).
i spent:
100 - trailing arms and hubs
80 - replaced one caliper
40 - rotors
50 - pads
TOTAL 270
hubs feel fine, bushings are good, but i do want to eventually repalce the other old caliper.
Old Dec 30, 2004 | 08:36 AM
mct121's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kysard &raquo;</TD></TR><TR><TD CLASS="quote">Used trailing arm assembly - $250
Brembo blanks - $60
Pads - $50
Total - $660 and hope that the used caliper is good</TD></TR></TABLE>
Four wheel disk brakes - Priceless
Sorry, someone had to say it....
Old Dec 30, 2004 | 08:37 AM
mrlegoman's Avatar
Default Re: hidden costs for rear disk brakes (Mike C)
If you track your car often and have upgraded your front brakes, you might think about the fastbrake rear upgrade kit too. I noticed a considerable improvement in straight line braking after installing the kit.
drum brakes
Old Dec 30, 2004 | 08:50 AM
endlesswinterco's Avatar
Default Re: hidden costs for rear disk brakes (mrlegoman)
i think discs all around is really good. you must be able to stop the car before you can go fast
Old Dec 30, 2004 | 08:58 AM
Mike_C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrlegoman &raquo;</TD></TR><TR><TD CLASS="quote">If you track your car often and have upgraded your front brakes, you might think about the fastbrake rear upgrade kit too. I noticed a considerable improvement in straight line braking after installing the kit.
drum brakes </TD></TR></TABLE>
could this have been due to a different rear pad compund? i find it hard to believe that a stock disc can be overworked... the rears don't really do that much.
also, bigger front brakes are FAR more important than getting rear discs. put your money where it matters the most
Old Dec 30, 2004 | 09:07 AM
Targa250R's Avatar
be professional
Brembo blanks - $60
Pads - $50
I just can't see that this is worth it? Is there a better (cheaper) way?</TD></TR></TABLE>
You don't need the trailing arms or bushings if your existing bushings are good. The disc brake hub assemblies will bolt to your stock trailing arms. New bearings aren't really necessary unless one is bad.
Old Dec 30, 2004 | 09:25 AM
mrlegoman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">
The fastbrake kit uses the same oem calipors (thus the same brakepads) (I'm running Bobcats) I didn't think they would make that much of a difference but by increasing the rear rotor size (and I did not adjust the brake ballance), it did make the rear brakes work more.
also, bigger front brakes are FAR more important than getting rear discs. put your money where it matters the most </TD></TR></TABLE>Absolutly. A quick upgrade is the GSR calipors. They bolt right onto the front spindles of my old EX. And you can get those at Autozone for ~120$ for the pair.
But the rear swap should not cost you any more than 350 with all good parts.
just my experience.
Old Dec 30, 2004 | 09:47 AM
wilsel's Avatar
No ones factored in the cost of a prop valve, or upgraded MC.
Old Dec 30, 2004 | 03:58 PM
Mike_C's Avatar
Default Re: hidden costs for rear disk brakes (wilsel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wilsel &raquo;</TD></TR><TR><TD CLASS="quote">No ones factored in the cost of a prop valve, or upgraded MC.
because you don't need them?
kaivorth
Honda Civic (2001 - 2005)
Jun 3, 2013 11:36 PM
Jim Dan
Apr 17, 2013 12:42 PM
gohonda
Oct 9, 2007 01:40 PM
eltigre
May 16, 2006 04:49 PM
96 SOHC VTEC
Nov 30, 2002 07:49 PM
