question about how much to torque to apply to the rod bolts !!!!
Old Dec 29, 2004 | 10:41 PM
EK FLY's Avatar
Default question about how much to torque to apply to the rod bolts !!!!
how much to torque to apply to the rod bolts !!!! I ask my teacher and he said there is a special amount of torque that u apply with a torquimeter to the bolts that hold the rod with the crank ?? any clue
sorry for my bad english
Old Dec 30, 2004 | 06:25 AM
dwnthehatch's Avatar
Default Re: question about how much to torque to apply to the rod bolts !!!! (racing_beat)
What motor?
Old Dec 30, 2004 | 06:27 AM
EK FLY's Avatar
Default Re: question about how much to torque to apply to the rod bolts !!!! (dwnthehatch)
b18c1 stock rods
Old Dec 30, 2004 | 05:10 PM
EK FLY's Avatar
comon someone should know about this
Old Dec 30, 2004 | 06:06 PM
untitled's Avatar
I hope you torque your mains let alone everything else to proper specs...
If they are ARP rod bolts on the rods you pictured there should of been a instrustion sheet come...
T4eg's Avatar
14 ft/lbs 1st then 23 ft/lbs on STOCK gsr rods
Chris
Old Dec 30, 2004 | 06:27 PM
EK FLY's Avatar
Default Re: question about how much to torque to apply to the rod bolts !!!! (BlueHatch00)
THANK MAN!!
Old Dec 30, 2004 | 09:36 PM
Evs-One's Avatar
Solbros Owns Me
use a rod bolt stretch gauge...the most accurate way of torquing the bolts
Old Dec 31, 2004 | 12:11 AM
JDMorgan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racing_beat &raquo;</TD></TR><TR><TD CLASS="quote"> I ask my teacher and he said there is a special amount of torque that u apply with a torquimeter to the bolts that hold the rod with the crank ??</TD></TR></TABLE>
normally you use a torque wrench.
Old Dec 31, 2004 | 04:42 AM
X2BOARD's Avatar
23 ft/lbs ? I could swear it's 28 ft/lbs for gsr eagles.
I recommend you contact arp directly tho... they will give you the info no problem. Torque specs are something you need to be definite about.
Old Dec 31, 2004 | 06:18 AM
EK FLY's Avatar
Default Re: (X2BOARD)
thank for those who reply but yeat i have the stock gsr rods not aftermarke I wanted to know bfore I put ma b18c1 together
b20vtech
Apr 20, 2007 08:51 AM
allmotrwagn
Nov 30, 2006 10:03 AM
CA6VTEC
Dec 12, 2005 10:17 PM
nortrop
Aug 16, 2004 06:03 AM
S13 slide
Jan 8, 2002 09:29 AM
