93 Ls questions
my friend is planning on buy this car but i dont kno if its good or not and since you guys here are smart with this things imma see wat u guys think.
Uberdata chipped pr4 ecu
Fmax manifold w/ egt bung with plug for tuning
T3/T4 turbo 57 trim .63 ar housing
Spearco FMIC
RC 550cc injectors(saturated/high impedence)
2.5 mandrel bent charge pipes
Tial 35mm external wastegate
1st gen DSM BOV(uncrushed)
K&N filter
B&M fuel pressure gauge installed on fuel filter
Walboro 255lph fuel pump
Action 2ks clutch disc and pressure plate
ACT flywheel
Custom 2.5" mandrel bent downpipe and exhaust
All this is in a 1993 Integra Ls so wat u guys think? Please reply asap since hes gotta kno soon cuz the cars not gonna be sold for long. Thanks an advanced!
~Eric
Spearco FMIC
K&N filter
ACT flywheel
~Eric
How much is it selling for? Personally i wouldnt buy it since most likely the motor has been beat the hell up, who knows what the owner did to it before. Because of that, its risky buying it since it might be abused/damaged internally. I guess you can do a compression or leakdown test on it, but theres other things that you cant check unless you tear the motor apart.
The turbo setup is nice tho
I would think about it but ask the seller to have a compression test before i buy it because of the old motor plus a turbo, plus it was probably beat on, cause who wouldnt beat on there car if they had a turbo, but i had a da n loved it so if its all good under the hood the hop on it
da's are amazing
da's are amazing
Yea compression/leakdown test would tell you if the rings and valves and stuff are still good. But I still would be skeptical about things like the crankshaft bearings, condition of the bearings in the turbo, etc.
97Preludeguy
May 15, 2008 03:47 PM
93LSivic
Jan 3, 2002 01:18 PM
But wat if the engine is good and not beat up and all?
