max boost on a stock d16y8?
Old Dec 29, 2004 | 08:08 PM
Tapen00n's Avatar
Default max boost on a stock d16y8?
how much boost can i pump into my stock d16y8
Old Dec 29, 2004 | 08:32 PM
SOHC_MShue's Avatar
Default Re: max boost on a stock d16y8? (Tapen00n)
you should be asking how much power can it handle...
Old Dec 29, 2004 | 09:28 PM
T25So's Avatar
210 on stock internals for me yo. 10.5 psi on a t25
Old Jan 4, 2005 | 05:43 AM
k24a4kid's Avatar
I'm a Jackass
Default Re: (T25So)
my friend was running 13lb with a t3 on his d15
Old Jan 6, 2005 | 03:08 AM
Itz Darave's Avatar
250whp is good... 300whp is pushing it...
Old Jan 24, 2010 | 09:43 AM
habhabcrx's Avatar
New User
i was windering the same thing,,how much boost?
Old Sep 27, 2011 | 09:31 AM
vtechdogg426's Avatar
I have a stock D16 y8 vtech engine in a 96 civic ex running on a auto transmission. I am
Putting a turbo kit on and was wondering what PSI would be save to run at with out any other mods?
Old Sep 27, 2011 | 09:32 AM
Also for a performance camshaft and pistons what would you guys recommend?
Old Sep 27, 2011 | 11:14 AM
JDM-sol 89's Avatar
It's vtec.. v-tech is a company that makes phones. I think, instead of spending that money on building a motor, you should spend some of it on converting it over to a 5 speed first. Otherwise, 10 psi will suffice for stock internals.
Old Sep 27, 2011 | 06:39 PM
SovXietday's Avatar
I run 16psi on my stock Y7 every day, but that means nothing unless I tell you which turbo I'm running... which conveniently you didn't tell us.
Old Sep 27, 2011 | 07:01 PM
hoffmanb16's Avatar
Wow auto trans, really?
Your y8 will be just fine it's that auto trans that is going to bust wayyyy before your motor does.
Better start saving up for a manual trans asap.
Old Sep 27, 2011 | 07:11 PM
BrothaSit's Avatar
you can boost 30lb with ease.
Old Sep 27, 2011 | 08:30 PM
hondahusted's Avatar
you better plan on some back up trannys because honda autos dont like turbos. I put 3 of them in my boosted honda crv in three months. it got a little costly
Old Sep 28, 2011 | 09:31 AM
philly10psi's Avatar
i got 10psi on my d16z6 daily driver on a t3 turbo...plenty of power...right around 210whp
Old Sep 29, 2011 | 06:14 AM
phat00civic's Avatar
I would agree for reliability 210 whp is the max from my own research and what my car is at. Technically 209.5 whp. Max boost is set to 10lbs. I think the better question as mentioned is what turbo do we run, at what PSI, and what whp do we have. And yes you will need a manual tranny before the turbo, or have the auto rebuilt for turbo but that gets $$$ and fast.
TD05H - 15G
10lbs
210whp
Crome chip
Old Sep 29, 2011 | 12:59 PM
b20vtech's Avatar
10psi is what I see most, usually any stock 16 valves d series can make around 200-215whp on 10 pound with a t3t4 50 trim or something similar to it. good luck
Old May 22, 2025 | 06:55 AM
Doug Simon's Avatar
if I may ask..what turbo are you running? And do you run stock internals as well? Any specific recommendations for parts? I have a 1997 EX. Looking to turbo but gotta rebuild first..new gaskets rods and pistons. It's my daily but needs some loving before I boost it.
Old Jul 2, 2025 | 01:08 PM
Rev-speed2025's Avatar
Like they all said its not the boost...
(Fyi all stock single cam s weak rods can only do about 183whp reliable...Period)
titi_vtec
Sep 7, 2010 11:19 AM
lileghatch
10
Mar 27, 2009 12:08 PM
hondastrtracr
10
Nov 11, 2007 02:14 PM
1SickHb
Jan 18, 2005 05:18 PM
zseeanz
Nov 16, 2003 07:56 PM
