What is the Benefit of Higher Oil Pressure?
Old Jan 7, 2002 | 07:54 AM
Flux's Avatar
Default What is the Benefit of Higher Oil Pressure?
I know there is a reason - who can help me learn here?
Old Jan 7, 2002 | 07:56 AM
Willard's Avatar
Default Re: What is the Benefit of Higher Oil Pressure? (Flux)
To overcome pressure drops for add-on's such as large oil coolers/turbo's/etc.
To much pressure = trouble.
Will
Old Jan 7, 2002 | 07:59 AM
Mike K's Avatar
Well, on a stock motor you will probably lose power with increased oil pressure.
On a modified motor where the bearing clearances are looser than stock, you'll benefit from the extra pressure.
Too much pressure will result in power loss all around.
Old Jan 7, 2002 | 08:00 AM
HX_Guy's Avatar
Default Re: What is the Benefit of Higher Oil Pressure? (Mike K)
Too bad Hondata doesnt log oil pressure..that would be badass
...fuel pressure would be sweet too
Old Jan 7, 2002 | 08:02 AM
jeff652's Avatar
What's the stock tolerance for oil pressure? How much is too low, how much is too high?
Curious, as I'm too lazy to look in my hemls~
Old Jan 7, 2002 | 08:08 AM
HX_Guy's Avatar
Default Re: What is the Benefit of Higher Oil Pressure? (jeff652)
I think its 50 PSI @ 3000 RPMs and youre good.
Also another good rule of thumb Ive heard is 10 PSI per 1000 RPMs is good.
Old Jan 7, 2002 | 08:19 AM
newspeedR's Avatar
so is there any real easy way of adjusting the oil pressure... besides a pump or gears
Old Jan 7, 2002 | 08:25 AM
Mike M's Avatar
Founding Member
Default Re: What is the Benefit of Higher Oil Pressure? (newspeedR)
Smaller oil filter will cut down on the drop in pressure
Old Jan 7, 2002 | 08:27 AM
Jason's Avatar
Default Re: What is the Benefit of Higher Oil Pressure? (TypeRmsm)
but wouldn't the smaller filter be more detrimental w/ less of an ability to filter out unwanted particles?
Old Jan 7, 2002 | 10:50 AM
Mike K's Avatar
Default Re: What is the Benefit of Higher Oil Pressure? (typer98)
Not when it's OEM!
(Hint hint: RSX oil filter )
[Modified by Mike K, 2:51 PM 1/7/2002]
Old Jan 7, 2002 | 10:54 AM
HX_Guy's Avatar
Not when it's OEM!
Mike..more info please! Does it fit on the B blocks?
Old Jan 7, 2002 | 10:57 AM
Mike K's Avatar
Default Re: What is the Benefit of Higher Oil Pressure? (HX_Guy)
There's a good possibility that it does... and there's a good possibility that it increases oil pressure 5-10psi all around.
Now, SHHHHHHH!!
Old Jan 7, 2002 | 10:59 AM
HX_Guy's Avatar
LOL...VERY intresting! Now the quetion again is...
How much oil pressure is "perfect" and at what point do you have too much?
Old Jan 7, 2002 | 11:11 AM
py1188's Avatar
Now, SHHHHHHH!!
Now theres something I would have never thought of.
Very interesting!!! Can you elaborate a bit more?
Old Jan 7, 2002 | 07:04 PM
ITR#132's Avatar
The rsx oil filter does not fit, too small. It is the size of a motorcycle filter.
[Modified by ITR#132, 8:05 PM 1/7/2002]
Old Jan 7, 2002 | 07:06 PM
Mike K's Avatar
Default Re: What is the Benefit of Higher Oil Pressure? (ITR#132)
Unless you have tried it, and it did not fit on your car.. don't say it doesn't fit.
Because it does.
TJ_GANT
Jul 10, 2011 12:17 PM
hondaeg8
Feb 3, 2004 01:05 PM
hondaeg8
Jan 26, 2004 03:37 PM
r7
Aug 19, 2002 06:34 AM
