problems with vtec
Old Dec 29, 2004 | 02:09 PM
vegeta420's Avatar
Default problems engaging vtec
my buddies h22 won't engage vtec we where thinking it's the TPS or the siloniod ground any other reasons you guys can think of? we tried the TPS and relocated the ground and it's still not working
Old Dec 29, 2004 | 02:13 PM
GoFastMotorSports's Avatar
Default Re: problems engaging vtec (vegeta420)
ecu- But this just happened to my friend. You know what the problem was??? Huge dent in the oil pan. Also check the vtec solenoid. Run a power wire to it and you should hear clicking,if you do its good. If you dont try and clean it off and if that dosent work than you know its the solenoid
Old Dec 29, 2004 | 02:16 PM
vegeta420's Avatar
Default Re: problems engaging vtec (GoFastMotorSports)
we just put the motor in on sunday so there's no dents or anything but i'll check the solenoid thanks
Old Dec 29, 2004 | 02:17 PM
What car is this in?? And what is the ecu you are using? Any codes?
Old Dec 29, 2004 | 02:20 PM
vegeta420's Avatar
it's in a 98 accord lx and where running the h22 ecu. but the ecu reads 28 which i don't get because my friend said that his book doesn't display that high of a number.
Old Dec 29, 2004 | 02:21 PM
vegeta420's Avatar
also he has a skunk2 intake manifold with the stock throttle body
Novtecdohc
Nov 15, 2006 09:16 PM
94ludeh22
Nov 16, 2005 07:14 AM
dre23
Nov 13, 2005 12:35 PM
tr0n9h
Sep 13, 2005 06:20 AM
caLiH22A
Feb 28, 2003 05:48 PM
