Goodridge stainless steel brake lines daily driver?
Old Dec 29, 2004 | 01:21 PM
initialvtec's Avatar
Default Goodridge stainless steel brake lines daily driver?
Is there really any point to upgrade to these lines on a daily driver? My brake pedal does feel mushy right now, but i just ordered new rotors and brake pads along with the lines, but i'm having 2nd thoughts about installing them. I've been hearing people say that you need to check the lines often, because dirt might get in it and cause wear that you can't see unlike the stock lines. What are your guy's opinions? Anyone running them on a daily driver?
Old Dec 29, 2004 | 01:32 PM
MaskedAP1's Avatar
Default Re: Goodridge stainless steel brake lines daily driver? (initialvtec)
SSline only help with pedal feel.. as a daily, i wont use them
Old Dec 29, 2004 | 02:13 PM
1whitedc2's Avatar
i have good ridge lines in my daily driven GSR, not a problem at all, no matter what they're always gonna be better than oem cuz they're Ss and not rubber!!
Old Dec 29, 2004 | 02:28 PM
.water's Avatar
dont put away ur money that u dont need..OEM work just fine..buy something else like dig camera.lol or good rotors & pads
Old Dec 29, 2004 | 03:04 PM
Default Re: Goodridge stainless steel brake lines daily driver? (Chris DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris DC2 &raquo;</TD></TR><TR><TD CLASS="quote">dont put away ur money that u dont need..OEM work just fine..buy something else like dig camera.lol or good rotors & pads</TD></TR></TABLE>
too late I could always just sell it? But if there's no problems on a daily driven car.. i don't see why not.
Old Dec 29, 2004 | 03:11 PM
1whitedc2's Avatar
honda/acura oem brake lines are good, usually they won't suggest replacement unless the car is got high mileage, or you track it or drive hard quite often, it's really up to you, i felt an improvement on pedal pressure when i got my lines...they're cheap anyway, $110 or so? can't find a decent digital cam for that money...
Old Dec 29, 2004 | 03:16 PM
Default Re: (1whitedc2)
that's true.. my car is almost near 90k, so the line probably haven't been replaced since. Isn't it true you can't see the wear on the lines since of the steel braids covering the teflon?
Old Dec 29, 2004 | 03:27 PM
maxxdout's Avatar
Default Re: (initialvtec)
170K at time of death, never replaced OE lines. Spend you money on something else for a daily driver.
Old Dec 29, 2004 | 03:38 PM
Default Re: (maxxdout)
hmm, i also heard it easier to heel toe without the stainless steel lines?
Old Dec 29, 2004 | 04:12 PM
burnout289's Avatar
stainless steel lines are only stainless steel on the outside. and yes, it makes checking them for cracks difficult cuz you can't see through the braided ss. I thought of getting a set but after doing research it seems like they are more trouble than they are worth for a daily driver. tho I do not know how long they are intended to last, so they might be fine for as long as you have the car [depending on how long you plan to keep it]. I opted not to get them since there are better things I can do with the money.
Old Dec 29, 2004 | 04:17 PM
B2FiNiTY's Avatar
Default Re: (burnout289)
I highly recommend NOT running ss lines for a daily driver unless they are coated.
Old Dec 29, 2004 | 06:33 PM
Default Re: (B2FiNiTY)
aren't the goodridge lines coated with teflon or something? I think i'll end up selling them.
Old Dec 29, 2004 | 07:10 PM
1whitedc2's Avatar
what are some disadvantage for running ss lines for your daily commuter?
RaceMyGhost
18
Apr 8, 2008 11:11 AM
youngvedder
Nov 25, 2003 05:36 AM
nikolai.
10
Jun 9, 2003 06:42 PM
agent marlon
Mar 28, 2002 05:45 PM
D21X
Feb 26, 2002 05:09 AM
