H22A accord idling problem.
Old Dec 29, 2004 | 01:16 PM
Stoich EG2's Avatar
Default H22A accord idling problem.
So i have a JDM H22A in my '94 accord LX. it runs like **** in general. The idle is jumping up and down... my redline is 6500??? (some guy sold me an Automatic ECU saying it would work all the same, yeah right). could it be because one of my vacuum lines arent hooked up? IF that's so, i don't know where it goes anyway.
Old Dec 29, 2004 | 01:23 PM
Luisito825's Avatar
Default Re: H22A accord idling problem. (Advan06)
when i converted auto to manual, i had my jdm auto p13 plugged in for like 30 seconds and it didnt idle well. I think the auto ecu was looking for the signal from the tcm. Although some people say it has worked fine, that wasnt the case for me.
I have both of those hoses plugged up.
Old Dec 29, 2004 | 01:55 PM
AVcTcEoCrd's Avatar
Default Re: H22A accord idling problem. (ogbusboy)
the two ports on the left, jus loop a vacuum hose to those two ports. the one behind the manifold, that is why it is idling bad. there should be two ports on the side where that yellow hose is. one should go to the hard line that goes to that valve near the fender, and on mine, the back port is looped to the other port on the side. as far as the auto ecu goes, you have to get it converted. once the auto ecu is converted to 5 speed, it will be fine. an auto ecu will not work at all if it is not converted.
Old Dec 29, 2004 | 02:29 PM
Stoich EG2's Avatar
Default Re: H22A accord idling problem. (AVcTcEoCrd)
my ecu worked... it kinda just redlines at 6500... which is fuggen stupid when i can be getting 8200 with a MT ecu... prelude9999 needs to gimme my money back
Old Dec 30, 2004 | 10:10 AM
prelude9999's Avatar
I'm sure this thing is pissing you off but the ECU I sold you was fine, I don't rip people off. My guess is your JDM motor has no EGR valve and the ECU is looking for one and causing it to idle poorly. Or you don't have an EGR control solenoid.
Are you throwing any codes? A code 12 by any chance?
Old Dec 30, 2004 | 10:20 AM
AVcTcEoCrd's Avatar
Default Re: H22A accord idling problem. (prelude9999)
no egr valve wouldnt make the car idle bad. not hooking up the vacuum lines correctly will. and all JDM h22's do come with egr valve.
Old Dec 30, 2004 | 10:28 AM
Luisito825's Avatar
if he didnt switch the pins and the egr was hooked up the car would idle bad and/or shut off. The CEL wouldnt light up unless you drove around.
Old Dec 30, 2004 | 10:37 AM
AVcTcEoCrd's Avatar
i havent switched my pins and it runs fine, i just get the cel after i drive
Old Dec 30, 2004 | 10:40 AM
Luisito825's Avatar
my bad i shoulda mentioned for 94/95 accords.
Old Dec 30, 2004 | 11:16 AM
so one possibility is the EGR control solenoid is not hooked up (or not even there), right? i believe there are two vacuum lines running to it, plus wires to the ECU
advan, can you take a pic of the whole engine bay, or a few of them from different angles?
Old Dec 30, 2004 | 11:18 AM
Luisito825's Avatar
if the hose leading to the egr is on and the pins havent been switched the idle will be ruff. if its disconnected idle will be unaffected. if the egr plug(to the harness) is unplug its CEL city.
Old Dec 30, 2004 | 11:36 AM
Stoich EG2's Avatar
i was told it was a leak from my TB gasket.
possibly the ECU as well.
Modified by Advan06 at 1:12 PM 12/30/2004
Old Dec 30, 2004 | 11:46 AM
Stoich EG2's Avatar
oh and for prelude9999
https://honda-tech.com/zerothread?id=413035
Old Dec 30, 2004 | 12:11 PM
Stoich EG2's Avatar
https://honda-tech.com/zerothread?id=1049330
last post.
Old Dec 30, 2004 | 12:17 PM
Stoich EG2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benhatch101 &raquo;</TD></TR><TR><TD CLASS="quote">minor surging of the engine at idle.</TD></TR></TABLE>
stated being one problem with running AUTO ecu. i need my money back.
Old Dec 30, 2004 | 12:29 PM
Stoich EG2's Avatar
https://honda-tech.com/zeropost...42853
i bought this ECU. it was an AUTOMATIC ECU though. he claims he did not know... it has a BIG *** AT written and and circled on it with a thick pink marker... I assumed he knew it was a 5spd...since the post clearly stated it was...
Old Jan 8, 2005 | 11:22 PM
BIRD021's Avatar
vacume hoses dude
Old Jan 9, 2005 | 07:47 PM
weezo182's Avatar
Default Re: H22A accord idling problem. (BIRD021)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIRD021 &raquo;</TD></TR><TR><TD CLASS="quote">vacume hoses dude</TD></TR></TABLE>
Old Jan 9, 2005 | 11:25 PM
Stoich EG2's Avatar
Default Re: H22A accord idling problem. (weezo182)
i fixed it already LOL. it was idle adjustment screw =P
akhom
Dec 15, 2011 05:01 AM
hyperB16Turbo
Oct 29, 2003 01:34 PM
hungy
Dec 25, 2001 07:16 PM
