p28 versus p30
Old Dec 29, 2004 | 06:28 AM
Mr.E.G.'s Avatar
Default p28 versus p30
i have a 94 hatch with a b16. i know that the p28 ecu will operate this engine, but will it operate it correctly. i know it wont be exact, but i can get a p28 and add hondata later and save some money in the long run.
whats the verdict
Old Dec 29, 2004 | 07:06 AM
snatch's Avatar
Default Re: p28 versus p30 (Mr.E.G.)
I would say P30, but what is the B16 from? What year I guess is what I'm asking?
Old Dec 29, 2004 | 07:09 AM
Lee_Delso's Avatar
Default Re: p28 versus p30 (******)
I say get the p28 and run Hondata. But if you want to run stock for now then upgrade later then go with the p30, good luck trying to find it though.
Old Dec 29, 2004 | 07:14 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: p28 versus p30 (Lee_Delso)
the only differences are the vtec cross over, maybe a little in the fuel map, the rev limmit, and the knock sensor. you will be fiine with the p28 till hondata.
Old Dec 29, 2004 | 07:30 AM
snatch's Avatar
Default Re: p28 versus p30 (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lee_Delso &raquo;</TD></TR><TR><TD CLASS="quote">I say get the p28 and run Hondata. But if you want to run stock for now then upgrade later then go with the p30, good luck trying to find it though. </TD></TR></TABLE>
This is true, good luck finding a P30 ECU. P28's are much easier to come by and at $100-$125 it's not too bad.
Old Dec 29, 2004 | 07:39 AM
beerbongskickass's Avatar
Get a p28 and run uberdata.
Old Dec 29, 2004 | 08:21 AM
JDMlyfestyle's Avatar
I dont believe the P28's Ecu can handle a B series by itself without being chipped. Different vtec engagement, Different Fuel and Ignition maps. car would run like **** with the p28 if it ran at all.
Old Dec 29, 2004 | 08:45 AM
BrokeAssWhiteboy's Avatar
my house has wheels on it
either ecu has the ability to run hondata in the long run, the only difference on the p30 with hondata is you that you have a knock sensor
Old Dec 29, 2004 | 09:32 AM
Mr.E.G.'s Avatar
i have driven a couple of b16 civics with a p28 ecu. i didnt notice any problems. i know that a single cam makes less power and therefore uses less fule, so the fuel maps are not going to be the same and the revlimiter is different and so forth. i guess i am asking if it will be safe, until i can get hondata. in the end once hondata is installed, it wont really matter which ecu i have.
Old Dec 29, 2004 | 09:34 AM
if you run the p28 make sure it is chipped for a dohc vtec, i wouldn't trust a soch fuel map to run my engine
Old Dec 29, 2004 | 09:36 AM
nsxmatt's Avatar
Why waste money on Hondata for a stock B16 motor? Throw a p30 in it or a chipped p28.
Old Dec 29, 2004 | 09:37 AM
Default Re: p28 versus p30 (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">Why waste money on Hondata for a stock B16 motor? Throw a p30 in it or a chipped p28. </TD></TR></TABLE>i have seen hondata make some nice gains on fairly stock engines
who is to say what justifies having hondata if that is what he wants then more power to him
Modified by BrokeAssWhiteboy at 7:07 PM 12/29/2004
Old Dec 29, 2004 | 10:08 AM
nsxmatt's Avatar
Default Re: p28 versus p30 (BrokeAssWhiteboy)
He asked what is better for his B16, I gave my opinion which is on a stock B16 I don't feel a full Hondata setup and the need for a dyno tune is cost effective for the power he will make over a simple chipped p28 or p30.
Old Dec 29, 2004 | 10:22 AM
ian.'s Avatar
p30
Old Dec 29, 2004 | 11:25 AM
jdmjade's Avatar
I would run a P30. So that you wont be rushed to get Hondata with a P28, and the car would be running with the right ecu in it until you get the Hondata.
Old Dec 29, 2004 | 11:37 AM
crxkane's Avatar
Default Re: p28 versus p30 (jdmjade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjade &raquo;</TD></TR><TR><TD CLASS="quote">I would run a P30. So that you wont be rushed to get Hondata with a P28, and the car would be running with the right ecu in it until you get the Hondata.</TD></TR></TABLE>
OR like it has been said the P28 chiped for dohc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">I dont believe the P28's Ecu can handle a B series by itself without being chipped. Different vtec engagement, Different Fuel and Ignition maps. car would run like **** with the p28 if it ran at all.</TD></TR></TABLE>
The car would run but not like the motor should. With my gsr swap i had a obd2 p72 and could not use it on my 94 ex civic and i used my p28 for the drive to the shop to get a obd1 p72 and the wire for the knock sensor. so the car will run just not to the best of its pot....
Old Dec 29, 2004 | 12:49 PM
Default Re: p28 versus p30 (crxkane)
People still buy Hondata? lol...
Uberdata is the same thing and it's free.
Old Dec 29, 2004 | 04:58 PM
simplypinoyy's Avatar
Default Re: p28 versus p30 (beerbongskickass)
go with the p28, its the most tuneable ecu that a lot of people use when going obd1... better to go with in the long run
Old Dec 29, 2004 | 05:01 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: p28 versus p30 (simplypinoyy)
just find a rechipped P28, and then get someone to chip you a P30 program and call it a day.
Old Jan 8, 2005 | 05:13 AM
EF9panda's Avatar
Default Re: p28 versus p30 (AzntaggeR)
i got a usdm p30 for sale .. pm me if anyone is interested...
Old Jan 8, 2005 | 05:25 AM
Plugs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simplypinoyy &raquo;</TD></TR><TR><TD CLASS="quote">go with the p28, its the most tuneable ecu that a lot of people use when going obd1... better to go with in the long run </TD></TR></TABLE>
What he said.
JakeSpec
Mar 10, 2009 10:43 AM
scuffywin
11
May 1, 2007 09:12 AM
KiNG $h!t
Jul 24, 2004 10:59 PM
Stroker
Apr 23, 2003 06:46 PM
