can i drive home if...
Old Dec 28, 2004 | 10:13 PM
fafsa's Avatar
Default can i drive home if...
im going to get my dp and ic piping done on thursday. i was wondering if i could drive home on a my n/a map that im running right now? ill still be running stock injectors and everything. if i dont go into boost it should be ok right? jw if i can do this w/o damaging anything
Old Dec 28, 2004 | 10:14 PM
m R g S r's Avatar
Default Re: can i drive home if... (fafsa)
Normally when you go up hills and ****, it's kinda hard not to boost the motor. It's do-able, but not recommended. . .
Old Dec 28, 2004 | 10:28 PM
fafsa's Avatar
Default Re: can i drive home if... (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Normally when you go up hills and ****, it's kinda hard not to boost the motor. It's do-able, but not recommended. . . </TD></TR></TABLE>
its pretty much just strait flat road its about 12-13 miles, from my house, which ill install the rest of my turbo stuff- injectors,fuel pump, boost and oil pressure gauge
Old Dec 28, 2004 | 11:10 PM
Drew Peacock's Avatar
You'll be fine hook up your boost gauge so you know when to back off the throttle if need be.
Old Dec 28, 2004 | 11:32 PM
u2civic1's Avatar
well if your ic piping isn't on u won't be boosting at all
u just have to be carefull about over spinning the turbo
Old Dec 29, 2004 | 12:27 AM
Nikoli's Avatar
Default Re: can i drive home if... (u2civic1)
i drove my car from charleston to miami on an NA map
Old Dec 29, 2004 | 05:57 AM
tgreaves's Avatar
Default Re: can i drive home if... (Deckedlude)
If you do start to boost up your car will fall on its face because the ecu will do a fuel cut.. Youll be fine..
Old Dec 29, 2004 | 08:03 AM
fafsa's Avatar
Default Re: can i drive home if... (tgreaves)
thanks everyone
JDM As It Gets
Dec 14, 2006 12:13 PM
nicktagz
Aug 28, 2006 07:56 PM
kabaroo
Jul 18, 2004 03:27 PM
honkey2fly
May 26, 2004 11:56 AM
igo4bmx
Apr 22, 2003 08:39 AM
