Turbo oil line feed location
I have a funky question. Did anyone use the Vtec oil pressure sensor (the one mounted on the side and has 2 wires) oil port for a turbo oil feed. If it's possible, then i can use a shorter line and may look better.
yesh behind the block might be harder to access but once you do it right you wont have to fuss with it later...also you might pull too much oil pressure from the head that might cause vtec to not be engaged on the top end
DR. ON POINT
Sep 19, 2002 09:31 AM
