ECU problems?
Old Dec 28, 2004 | 08:30 PM
Cone's Avatar
Default ECU problems?
ok, I have an Apexi Power FC on my '00 ITR. Now, I used a Kenji harness to convert to OBD2b to OBD2a. I put in my Power FC and the stock tach stopped working. I emailed Kenji, he said to check continuity between OBD2b side pins B13 and A19 (looped together) to OBD2a side pin A20. Everything checked out fine. I plugged in my stock USDM P73 and the stock tach worked. I then tried switching the harness on my friends car with a Power FC and the harness checked out fine on his (stock tach worked). I then tried my friends OBD2a P72 using the harness and my stock tach worked...sooooooooo....is my Power FC bad? Is there any signal problem? Any ideas? I'm pretty sure that since the distributor signal (B13) and ICM signal (A19) are spliced and run to ICM (A20), they are the same signal, and thus, it shouldn't affect the stock tach. The Power FC has a good tach signal, so I'm lost? TIA.
-Andrew
EDIT: BTW, I'm running a JDM B18C.
Old Dec 29, 2004 | 07:49 PM
Cone's Avatar
Default Re: ECU problems? (Stealth 95 GS-R)
OK, with the help of Boomslang and Kenji, I fixed my problem. I had a 10 wire dist. and a 9 wire plug? lol, anyway, I just spliced the blue wire coming off the dist. (which wasnt mated to anything on the harness) into the ICM wire and it works now. Thanks.
Old Dec 29, 2004 | 07:56 PM
Chris F's Avatar
Cheers!
-Chris
firejackal
13
Oct 28, 2015 03:02 PM
stdefhatch
Jul 2, 2015 04:47 PM
lsvtec101
Aug 24, 2004 01:31 PM
WhiteEG6
May 20, 2004 03:57 AM
Mikey3000
Jun 28, 2002 01:50 PM
