Fitting Oil Temp Gauge.
Put that beast in the pan , is it a mechanical or electric, The oil temp will be more consistant in the pan since it will be covered in oil all of the time and not be effected by the heat of the cylinder head
nope, but put it I usually put it on the front side about 2in up from the bottom about 2 from the timing belt side. Check out where the plugs are on a moroso oil pan and you will see
CRVTEC0WNZJ00
10
Oct 3, 2005 07:45 AM
