Honda S2000 Honda S2000
anyone else have tranny/diff noise?
Old Dec 28, 2004 | 07:06 PM
Louie's Avatar
What would Chente do?
Default anyone else have tranny/diff noise?
Wifey's 03 S2K has some tranny and diff issues. As far as the tranny goes, it seems the imput shaft bearing is going bad. While at idle in neutral it has a growling noise from the tranny. Pushing in the clutch, the noise winds down and stops. Releasing the clutch noise is back again. Slam dunk right? Well, since it is still under warranty i brought it in to the dealer and they state this noise is normal and that honda has released a bulletin stating this.
Second is the noise from the rear diff. Growling that can be heard a low speeds and more so when on the hwy at light throttle or slight deceleration. Again dealership states these noises are normal which i would be okay with if they were present from day but not the case.
Oh well, chime in if ya'll are hearing the same stuff. Thanks.
Louie~ who is a master tech and knows better.
Old Dec 28, 2004 | 07:39 PM
ITRbroham's Avatar
shit post warrior
Default Re: anyone else have tranny/diff noise? (Louie)
That's definitely not normal.
No noises whatsover from my S2K tranny or diff.
Old Dec 28, 2004 | 07:43 PM
papa5murf's Avatar
Default Re: anyone else have tranny/diff noise? (ITRbroham)
nothing from my 03.. and i drive my baby hard..
Old Dec 28, 2004 | 07:44 PM
papa5murf's Avatar
Default Re: anyone else have tranny/diff noise? (03s2kblue)
have you changed your fluids???
Old Dec 28, 2004 | 08:34 PM
Razor's Avatar
well the s2000 does have a noisy throwout bearing from teh factory, however it shouldn't be excessively loud.
Old Dec 29, 2004 | 12:02 AM
Echo7847's Avatar
Default Re: anyone else have tranny/diff noise? (Razor)
The only bulletins out for trans noise are: a noisy clutch pedal, and grinding while upshifting when the engine is cold. Sounds like someone doesnt want your warranty work.
Noise is not normal. If they do look it it they'll try and diag it as the throwout bearing. Then they'll realize it was the ISB and do it again.
Old Dec 29, 2004 | 06:09 AM
fknfast's Avatar
Default Re: anyone else have tranny/diff noise? (Echo7847)
clutch plate springs make noise. they get loose and rattle
EFPhilly
28
May 14, 2009 09:19 AM
99teg
Jun 14, 2006 02:44 PM
willyboyK20
Aug 23, 2004 05:27 PM
E-lude78
12
Mar 12, 2002 05:37 AM
