Noticed one of my CV boots is about shot
Old Dec 28, 2004 | 07:00 PM
Intercooler's Avatar
Default Noticed one of my CV boots is about shot
When changing the oil today I noticed my driver's side boot is getting pretty cracked and will need replaced after the Winter. Does a good speedy boot exist for this? Is it a PITA? How much should a shop charge to just replace the boot?
Old Dec 28, 2004 | 07:19 PM
eK9aT10pSi's Avatar
Default Re: Noticed one of my CV boots is about shot (Intercooler)
itd be cheaper to get an autozone reman axle, like 55 +core. bout 1 hr to do, not too bad.
Old Dec 28, 2004 | 07:27 PM
Aren't the boots like $10?
Old Dec 30, 2004 | 08:25 PM
eK9aT10pSi's Avatar
but if u put a new boot, the bearings are going to be covered in ****. by the time you clean the bearings, regrease, replace the bearings, and put the boot on, you might as well coulve got the whole thing
Old Dec 30, 2004 | 08:27 PM
SyDuck's Avatar
Default Re: Noticed one of my CV boots is about shot (eK9aT10pSi)
replacing the bearings is a bitch trust me. took me and a friend like 2 hours to do one side by hand x1948
Old Dec 30, 2004 | 08:32 PM
I thought you only had to do that if they were bad. My boot isn't tore yet but on its way. So just putting a new speedy boot on an otherwise perfect CV joint is a no-no?
Old Dec 30, 2004 | 08:56 PM
eK9aT10pSi's Avatar
no becuase while ur driving, it picks up **** and goes all over the bearings and whatnot. IMO itd be a better idea to change it completely. same amount of work. still gotta pull the axle. so do it right the first time and not worry about it
Old Dec 30, 2004 | 09:14 PM
RedHB..D15B's Avatar
go to autozone, give them your old axle(core), buy a new one, then put it in and you dont have to worry about ****...it should only take like 15 min to do (one side)
but if its your first time it will take a little longer...happy fixin'
Old Dec 30, 2004 | 09:16 PM
It isn't tore through yet. Just starting to get a crease. Why would you need to pull the axle to do a speedy boot? The best I can remember when I did one on my Tercel you just cut the old one off, lube the joint and snap the new boot in place (it is cut on one side) and apply clamps. Or have they changed since the last time I did it? To put a full boot on I know you have to take the axle out.
Old Dec 30, 2004 | 11:18 PM
Street Ghost's Avatar
Wtf? This speedy boot you're talking about sounds like a temporary *** fix. Already cut? Held on by clamps? Might as well just replace the entire axle and be done with it.
Old Dec 31, 2004 | 10:31 PM
eK9aT10pSi's Avatar
no use in doin temp fixes. do it right the 1st time so you dont have to deal with it again [hopefuly]
Old Dec 31, 2004 | 11:36 PM
97civicdx's Avatar
Intercooler: If you want to just change the boot. then by all means go for it. It is easier to just replace whole axle that way you get all new stuff. The boot will break eventually, trust me. It isnt that much mmore work to get the axle off. Thats what everyone has been trying to say.
Old Jan 1, 2005 | 06:49 AM
Joon Joon's Avatar
Default Re: Noticed one of my CV boots is about shot (97civicdx)
sorry to hijack ur thread but i wanted to know why the boots tear.. i had a torn boot and my mechanic just replaced it for like 20bucks.. then like a week or two it tore again.. wat would cause this??
Old Jan 1, 2005 | 01:27 PM
97civicdx's Avatar
Default Re: Noticed one of my CV boots is about shot (vtecenjun)
the speedy boot doesnt slide on the axle shaft, it wraps around then u glue it together, like a wrapper. The glue fails and you have problem all over again. Get a reman axle!!
Old Jan 1, 2005 | 08:28 PM
Joon Joon's Avatar
i thought the boot slides on.. the boot that my mechanic put on didnt look like it was glue and it tore inbetween the humps of the boot..
seaterk
Dec 27, 2009 10:23 PM
ProjectDarkBlack
May 13, 2007 01:57 PM
spicoli
Jan 10, 2005 10:13 AM
krnboixshawn
Jun 4, 2003 05:39 AM
senpai
Jul 22, 2002 08:50 PM
