RPM Launch Point
Old Dec 28, 2004 | 02:42 PM
gbinteg's Avatar
Default RPM Launch Point
I Drive a 2000 GSR. It has i/h/e and i was wonderin to get the best quarter mile time and the best launch what RPM's do you launch at?
Old Dec 28, 2004 | 02:46 PM
RidinStock's Avatar
Default Re: RPM Launch Point (gbinteg)
What kind of tires do you have? Assuming that it is a stock clutch, probably anywhere between 2-3000 if you like to drop the clutch. 4-5000 if you like to feather. Your best bet would be to find an empty road and practice. Just expect to replace your clutch soon if you do it a lot...
Old Dec 28, 2004 | 06:01 PM
JDM_Spec's Avatar
Default Re: RPM Launch Point (RidinStock)
8K RPM sounds right. and drop the clutch and hold the gas pedal down
Old Dec 28, 2004 | 06:14 PM
CNSK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinStock &raquo;</TD></TR><TR><TD CLASS="quote">What kind of tires do you have? Assuming that it is a stock clutch, probably anywhere between 2-3000 if you like to drop the clutch. 4-5000 if you like to feather. Your best bet would be to find an empty road and practice. Just expect to replace your clutch soon if you do it a lot...</TD></TR></TABLE>
Old Dec 28, 2004 | 07:32 PM
Teggers's Avatar
Default Re: RPM Launch Point (JDM_Spec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">8K RPM sounds right. and drop the clutch and hold the gas pedal down</TD></TR></TABLE>
Are you serious?
If my simulators results have any bearing in reality, drop at about 3000 rpm. If you dont want to drop, slip it at about 1600 rpm, but it may not give as quick a time as dropping (although it will put less stress on your drivetrain, but more on wear on your clutch). Just use these as a guideline and experiment at the track.
Old Dec 28, 2004 | 08:07 PM
a1320addict's Avatar
Default Re: RPM Launch Point (Teggers)
hes being sarcastic..typical
honestly...you need to find where you are comfortable launching it from
wheel hop is bad in the qt
im by no means a pro at launching..but i found getting a smoother launch at around 25-3k will result in a much smoother run
if you can get that down pat...maybe move up to about 4k....i do know some people like to launch in vtec...thats more of a preference though
just find a safe open road and practice...like someone said earlier...but be careful....hard launches...might be fun in the meantime...but when you gotta shell out $$ to buy a new clutch
DarkRattle
Transmission & Drivetrain
Jul 5, 2017 04:24 AM
ericsi
Jun 30, 2004 08:33 AM
.M.
Mar 28, 2004 03:07 AM
nickw252
Mar 13, 2003 10:59 AM
MysticAzn03
Jan 23, 2003 09:40 AM
