installing turbo in about an hour, octane question
Old Dec 28, 2004 | 12:08 PM
Scean's Avatar
Default installing turbo in about an hour, octane question
ok my cars been parked for a lil so i filled it up w/ premium today because of the turbo install but there was prolly a little under a third of a lower octane gas in it, so the questoin should i retard or advance the timing and more or less because of the lowerd octane in there??
Old Dec 28, 2004 | 01:08 PM
Muckman's Avatar
Moderator in Chief
Default Re: installing turbo in about an hour, octane question (blackcivic95)
advancing your timing would be bad.
however if your not boosting alot, you maybe fine with the deluted fuel.
Old Dec 28, 2004 | 01:43 PM
PM-Performance's Avatar
im sure your not driving directly to the dyno. so you wont be boosting much until it gets tuned right? then i wouldnt worry about it
Old Dec 28, 2004 | 01:52 PM
Scean's Avatar
Default Re: installing turbo in about an hour, octane question (itr206)
sorry lemmie rephrase the question, im running uberdata, the usual basemap ignition retard is anywheere from like .75-1, so on that scale, which side should i tilt toward for haveing a lower valued octane fuel
DA 4 Lyfe
Jan 17, 2015 08:28 PM
Rishiras
Mar 28, 2006 08:26 PM
alexsracing
May 12, 2005 06:28 AM
99civ
Jul 6, 2004 03:15 PM
krshultz
15
Dec 27, 2001 10:40 AM
