line honing Cam caps?
i havent bought replacement cam caps yet but when i searched it some people said they had to be line honed or line bored?? What exactly does this mean, is it like milling a little bit off? Also, who could do it..just any machine shop?
remember the caps are bearings persay... and each head's caps have been line bored from the factory to assure their clearances are perfect... If you use caps from a different head, it is likely that the clearances wont be the same. get it? you will need to have the new caps line bored at a machine shop to make sure.
you can not buy new caps from honda either unfortunately.
You can use caps from other heads...
They aren't like bearings...if that was the case, you couldn't use 'any' B-series cam and have them completely interchangable.
Just do this:
Put the new cam caps on with the cams you plan on using.
Lube the Journals
Torque to spec...
Turn the Cams with a Wrench...
If they don't physically bind, you should be alright.
I've done this on numerous occasions and never had a problem.
Just do this:
Lube the Journals
Torque to spec...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote">Turn the Cams with a Wrench...</TD></TR></TABLE>
Cams should be able to turn by hand if the rockers are not installed.
