which ecu is better
Old Dec 27, 2004 | 08:36 PM
arielmalespin's Avatar
Default which ecu is better
i have a p72 redline is around 8100 i think and vtec engages at 4200 so they selling me a type r ecu i think he told me it was a p73 his asking 200 do u think i should buy it or stick with my p72?
Old Dec 27, 2004 | 09:35 PM
DavidT or VajT's Avatar
Default Re: which ecu is better (arielmalespin)
A real P73 ECU for $200 isn't a bad deal. I'd go for the P73 over the program you currently have. Up to you though...
Old Dec 27, 2004 | 10:32 PM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arielmalespin &raquo;</TD></TR><TR><TD CLASS="quote">i have a p72 redline is around 8100 i think and vtec engages at 4200 so they selling me a type r ecu i think he told me it was a p73 his asking 200 do u think i should buy it or stick with my p72?
which motor are you planing to use the p73 if you gonig to buy it?
have you ever considered about the p28 civic ex 92-95? just need to be chipped
Old Dec 27, 2004 | 11:21 PM
OUTKAST_R's Avatar
the p73 has an immobilizer if it is a 99 00 year so you cant even use it without a checkengine light ...
on the usdm ecu there is no way to take it off.
take a p 28 chip it and have fun / **** obd 2
Old Dec 28, 2004 | 05:12 PM
Default Re: which ecu is better (yeegsr)
i already have the p72 on an ls/vtec i have a gsr head is obd2. i heard thaat the p72 is the best computer for a car without chipping it cuz vtec engages at 4200 rpm
Old Dec 28, 2004 | 06:13 PM
CNSK's Avatar
I got a p73 type r ecu..ill give it to you for 160 shipped....IM me....
Old Dec 28, 2004 | 07:00 PM
Default Re: which ecu is better (Moua)
WHAT THE REDLINE AND ALSO WHEN DOES VTEC ENGAGES?
Old Dec 28, 2004 | 08:49 PM
CNSK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arielmalespin &raquo;</TD></TR><TR><TD CLASS="quote">WHAT THE REDLINE AND ALSO WHEN DOES VTEC ENGAGES?
vtec at 5800 and cuts off at 8700.....stock ecu....p73...
I have a teg gsr and stock vtec kicks a 4400 rpm(which you barely hear it, if even) and the secondary kicks in at 5800 just like any stock ecu would....and fuel cuts at 8200
Old Dec 28, 2004 | 08:56 PM
well my p72 that i have now vtec is at 4200 rpm now that low for a car that doenst have a vtec controller and my fuel cuts off around 8100 or 8200 i think im going to stick with this one. some people have told me ( i dont know if its right correct me if im wrong) that the p72 is better than a p73
Old Dec 28, 2004 | 11:35 PM
acuradriva's Avatar
it depends on the application. a p73 would be better if you had a b18c5. your vtec engages at 4400 unless you have the p72 chipped.
Old Dec 29, 2004 | 12:55 AM
iH8RICERZ's Avatar
Default Re: which ecu is better (acuradriva)
what are your mods..that will really determine what ecu I would recommend for you. I'm assuming your running the stock intake manifold and your car is pretty much stock, so I'd definately stick with your stock gsr ecu. The p73 ITR ecu will not control your secondaries in your stock gsr intake manifold...thus, loss in hp, torque, low and midrange power. But then again, its your car and the choice is yours. just my .02
Old Dec 29, 2004 | 05:17 AM
HONDA RR's Avatar
If your running with a gsr motor i say stick with the p72 ecu because if you use a p73 ecu a lot of sensors don't work causing a engine check light.
Old Dec 29, 2004 | 05:27 AM
sleevedgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITSUBA &raquo;</TD></TR><TR><TD CLASS="quote">If your running with a gsr motor i say stick with the p72 ecu because if you use a p73 ecu a lot of sensors don't work causing a engine check light.</TD></TR></TABLE>
My point Exactly.
Old Dec 29, 2004 | 06:34 AM
uzabatty's Avatar
Default Re: which ecu is better (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">assuming your running the stock intake manifold and your car is pretty much stock, so I'd definately stick with your stock gsr ecu. The p73 ITR ecu will not control your secondaries in your stock gsr intake manifold...thus, loss in hp, torque, low and midrange power</TD></TR></TABLE>
I'll 2nd that
I'm on the same boat...
go for the p73 if you get a single stage IM like skunk2 ir ITR and you don't want to worry about it. Otherwise get a p28 chipped as others have said
there are a bunch of threads talking about which is better depending on what you have... I'd search a bit
Old Dec 29, 2004 | 06:06 PM
at how many rpm does the vtev engages in a stock p72
Old Dec 29, 2004 | 07:12 PM
tank500999's Avatar
i would jsut chip the p72 and run uberdata
Old Dec 29, 2004 | 07:17 PM
uzabatty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arielmalespin &raquo;</TD></TR><TR><TD CLASS="quote">at how many rpm does the vtev engages in a stock p72</TD></TR></TABLE>
I believe @ 4400 rpm's
Old Dec 29, 2004 | 07:19 PM
tank500999's Avatar
bump
Old Jan 7, 2005 | 09:03 AM
acuradriva's Avatar
Default Re: which ecu is better (tank500999)
2 people already told you its 4400 is that why you are bumping it?
Old Jan 7, 2005 | 09:08 AM
BigPlansNoMoney's Avatar
Default Re: which ecu is better (CNSK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CNSK &raquo;</TD></TR><TR><TD CLASS="quote">
I have a teg gsr and stock vtec kicks a 4400 rpm(which you barely hear it, if even) and the secondary kicks in at 5800 just like any stock ecu would....and fuel cuts at 8200</TD></TR></TABLE>
Sorry got lost...
which of those specs are P72 and which is P73
InvaderTrax
Engine Management and Tuning
11
Oct 13, 2008 06:09 AM
memorybox
Nov 28, 2006 07:58 PM
robbizza
11
Sep 23, 2006 11:07 PM
Ignitecivic
May 12, 2004 08:18 PM
tolowhb
Aug 11, 2003 03:27 PM
