92-95 civic dash light problems????
Old Dec 27, 2004 | 08:06 PM
9civic5's Avatar
Default 92-95 civic dash light problems????
When I turn on my head lights at night I notice that my dash lights won't turn on right away and sometimes a few minutes later. I checked the fuses and they're OK! Any other suggestions is helpful!
By the way, I searched prior to posting and nothing worth the help. Thanks again.
Old Dec 27, 2004 | 08:09 PM
Hatch It's Avatar
Default Re: 92-95 civic dash light problems???? (9civic5)
Bad grounds, have you done any electrical work lately? Headunit install? Anything like that? Sometimes you can loosen a wire or ground, or maybe fry a wire....but check if you did any of that and trace your steps.
I had that problem after i installed my headunit, went back, used more of that good black tape, and it was
Good Luck
Old Dec 27, 2004 | 08:11 PM
frame's Avatar
Mine tend to do that. Also turn off later. or one side or the other will be on (of the 2 lights in the center console). HItting it usually gets them back on. Some strange bad connection. Will have to take it apart one day when I have time.
Old Dec 27, 2004 | 09:46 PM
BeavisB16's Avatar
Default Re: 92-95 civic dash light problems???? (frame)
I had that same problem, turned out to be the dimmer switch. If you hit (or tap it) the switch and it turns on, theres your problem.
Old Dec 27, 2004 | 09:57 PM
t0ekn3e's Avatar
i also have the same problem it hit the dash and they come on
Old Dec 28, 2004 | 09:29 PM
9civic5's Avatar
Default Re: (t0ekn3e)
Thanks guys! Appreciate the feedback
Old Dec 28, 2004 | 09:43 PM
lumpbuzcut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0ekn3e &raquo;</TD></TR><TR><TD CLASS="quote">i also have the same problem it hit the dash and they come on</TD></TR></TABLE>
me too. It sucks.
Old Dec 28, 2004 | 11:23 PM
BeavisB16's Avatar
dimmer switch!!!
Old Dec 29, 2004 | 01:39 AM
eJone powereD's Avatar
Default Re: (BeavisB16)
sometimes the bulbs behind get loose...so i just tap the dash
Old Dec 29, 2004 | 03:02 AM
Outrun's Avatar
Default Re: (eJone powereD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eJone powereD &raquo;</TD></TR><TR><TD CLASS="quote">sometimes the bulbs behind get loose...so i just tap the dash</TD></TR></TABLE>
Millenium Falcon that sucker!
DanGAvery
Nov 30, 2018 04:35 PM
PatrickGSR94
Oct 29, 2010 03:48 PM
213374U
Mar 30, 2008 01:17 PM
methos_tj
Acura TL, RL & ZDX
Jan 4, 2005 03:58 PM
TheJuggalo
Sep 3, 2002 12:35 PM
