Oil in my spark plugs holes? Help Please
I was trying to attempt to change my spark plugs when I took out one of the plug wires and it had oil on it, only 1 of the 4 plugs had oil on it. Do I have a bad headgasket? any idea on how much this will run me? Thanks fellow honda owners.
Was the oil on the sparkplug or on the tip of the plug. Sometimes a bad valve cover gasket can leak oil down onto a plug and when you pull it out ... you see oil.
Perhaps you can just tighten the valve covers. Wipe the area clean and see if the oil returns. You should be able to see where it is coming from after that.
