valve adjustment(labor)
Old Dec 27, 2004 | 12:51 PM
crxgator's Avatar
Default valve adjustment(labor)
ok, my car really needs a valve adjustment, and that is the only thing im afraid to do...now i remember it only being one hour labor(booktime/flatrate) yet now all the dealers by me want 110-150...i dont get it...but then again all the dealers in my area are owned by one group and i think because they made an monopoly they raised the prices on everything...
so is the labor rate only suppose to be 1 hour?
Old Dec 27, 2004 | 03:51 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: valve adjustment(labor) ([crx]I 3_AWP_BoyZ)
do it yourself, get some feeler gauges and the chilton for your motor, takes like an hour only if all the valves are outta wack, its really easy
Old Dec 27, 2004 | 03:57 PM
kylefakesi-r's Avatar
Default Re: valve adjustment(labor) (b2o-vtec)
.9 hrs technically x shop rate.
call them on it...i'm sure better business bureau would have something to say about that.
around here it is usually 79.95 since it doesn't require parts.
Old Dec 27, 2004 | 04:00 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Default Re: valve adjustment(labor) (kylefakesi-r)
or however much it costs for feeler gauges...its not that hard...
Old Dec 27, 2004 | 05:19 PM
Mr. B in Az's Avatar
From: Where the hell is Bullhead City, Arizona, U.S.A. Formerly of Huntington Beach, Ca 92649
step by step right here.....http://www.c-speedracing.com/h...t.php......super easy DIY
Old Dec 27, 2004 | 05:34 PM
DJ_SaNdOz's Avatar
Default Re: valve adjustment(labor) (Mr. B in Az)
If I can do it, you can do it.
Old Dec 27, 2004 | 11:14 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b2o-vtec &raquo;</TD></TR><TR><TD CLASS="quote">or however much it costs for feeler gauges...its not that hard... </TD></TR></TABLE>
There's nothing special about feeler gauges. A $5-10 metric set from Pep Boys should do the trick. At that price you can get both straight and bent.
Old Dec 28, 2004 | 01:56 AM
Twilight's Avatar
Default Re: valve adjustment(labor) (travis)
Good luck, and always remember to replace valve cover gasget.
Old Dec 28, 2004 | 03:37 AM
Slopoke's Avatar
Default Re: valve adjustment(labor) (Twilight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twilight &raquo;</TD></TR><TR><TD CLASS="quote">Good luck, and always remember to replace valve cover gasget.</TD></TR></TABLE>
You only need to replace the valve cover gasket if its cracked or leaking.
Killspeed93
Jan 26, 2011 05:35 PM
^jefs0ng
Oct 29, 2003 10:38 PM
io_burn
Sep 11, 2003 10:34 PM
RuskeR
May 16, 2003 10:39 AM
RStoR
Aug 2, 2001 01:30 PM
