Temp gauge and luke warm heat
Old Dec 27, 2004 | 08:46 AM
crxsiperf's Avatar
* B A N N E D *
Default Temp gauge and luke warm heat
My heat seems to blow semi hot but the car never gets hot inside until after im in there for what seems forever . I dont have much of the rear interior in the car so that might contribute some but it just seems like the heat isn't that hot and not enough comes out of the vents , also the temp gauge never gets in the middle , its gets a little over a 1/4 up and it was like that in the summer too. I just replaced with oem thermostat and it didn't seem to heat up anymore. I did a search and saw the cardboard in front of the rad trick , ill probably do that and also check the lines to see if on is hot and cold. Any other things i should check? And does anyone else have the problem of the needle never getting to the middle point?
Old Dec 27, 2004 | 08:47 AM
endlesswinterco's Avatar
Default Re: Temp gauge and luke warm heat (crxsiperf)
what temp. thermo did you get?
Old Dec 27, 2004 | 08:50 AM
crxsiperf's Avatar
* B A N N E D *
Default Re: Temp gauge and luke warm heat (RidinlowHatch)
NOt sure the exact temp but its an oe thermostat that would come with the car when bought , same temp , should i get the highest temp possible? This is a 94 eg hatch with a 98 ek engine.
Old Dec 27, 2004 | 08:55 AM
well i had the same problem last year, got the delsol b16 thermo, rated at like 165 degrees i beleive, helped me out. sorry, thats all i got for you
djfob
Feb 16, 2018 05:27 PM
agb22
17
Mar 7, 2017 07:11 AM
lilo_goki
Mar 27, 2011 09:38 AM
bandit080000
Dec 7, 2008 08:25 PM
electric-boost
Dec 11, 2006 08:37 PM
