oil problem
oil problem
99 civic si bone stock....... changed oil 1000 mile ago with mobil 1 10/30 and i checked the dipstick every week and i lose a lil a week but the 4th week the dip stick only half. so i had to add about almost a qt. today. what cause my car to burn synthetic oil? no leaks at all
Re: oil problem (dylokjai)
If I said it's normal, would that answer suffice?
It's thought that the high revving nature of the Honda motors make it "normal" to burn a little off.
It's also a normal trait of Mobil 1. So, combine the two, and it's slightly exaggerated.
I use Mobil 1 0W-20 in my bone stock 26,000 mile 02 Si, and it's down a quart by about 6000 miles.
Not that the K20A3 in my car is high revving, but I do use Mobil 1.
It's been discussed on http://www.bobistheoilguy.com if you care to read more into it.
And not all cars will burn oil, making it even more confusing.
Re: oil problem (jdmjade)
My D16z6 with ~111,000 miles uses NO oil not even a little, and I use Mobil 1 5w-30 and I rip VTEC all the time, is that like a sign that my motor is in really good shape? I mean I swear to God I fill it right to the full line on the dip stick and everytime I change it (Every 2500 miles) its still exactly on full, not even a centimeter lower
Re: oil problem (DelSolSi93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolSi93 »</TD></TR><TR><TD CLASS="quote"> is that like a sign that my motor is in really good shape? </TD></TR></TABLE>
Possibly. But I loose 1qt every 3K miles in my D16Y8 (110K miles). I rev high, and hit VTEC alot; but I just tested my compression, and it's 210 across the board. So the motor is healty, just burns a bit. Mobil 1 will burn off faster than other syns as well.
well,I know that your car doesn't relate to this example,but I have heard that cars that never used synthetic oil b4 will eventually leak from hard to spot places once the switch to synthetic is made.I myself have a d16z6 with like100,000 miles on it and I switched to synthetic oil [castrol syntec 10-40 all year round]like 2 yrs ago and the car has never burned or leaked oil.Maybe,you should try castrol oil. How long have you been using syntec oil?
trowe
23
03-29-2012 08:56 PM
GRAVEDIGGER
Honda Civic (2006 - 2015)
14
05-01-2007 09:34 PM
